Multi Editor 3D does not open multiple models [message #689528] |
Mon, 27 June 2011 19:12 |
New23D Messages: 3 Registered: June 2011 |
Hello
Essentially, this youtube.com/watch?v=fD5QLuPo-uE , doesn't work for me. Instead, when I drag n drop a second model to an already open multi editor 3D, a new tab (of multi editor 3D) is opened with the model that was intended.
Question: Am I missing something obvious on how this is supposed to work or is it a configuration issue at my end? I have only setup the GEF3D team project and started it as an Eclipse application. Created two models and attempted this.
Sample console output:
Jun 27, 2011 7:48:48 PM org.eclipse.gef3d.ext.multieditor.MultiPaletteRoot add
INFO: entry label_GEF3D newly added
Jun 27, 2011 7:48:48 PM org.eclipse.draw3d.graphics3d.lwjgl.Graphics3DLwjgl <init>
INFO: Graphics3DLwjgl constructor called
INFO: entry label_Class Diagram newly added
Jun 27, 2011 7:48:56 PM org.eclipse.gef3d.ext.multieditor.MultiPaletteRoot add
Jun 27, 2011 7:48:56 PM org.eclipse.draw3d.graphics3d.lwjgl.Graphics3DLwjgl <init>
My configuration is:
Eclipse 3.5/3.6/3.7 (tested on all three - Galileo, Helios and Indigo)
GEF3D: SVN rev. 585
java version "1.6.0_25"
Java(TM) SE Runtime Environment (build 1.6.0_25-b06)
Java HotSpot(TM) 64-Bit Server VM (build 20.0-b11, mixed mode)
GNOME 2.2 on Oracle Linux 6.0
Kernel: 2.6.32 SMP x86_64
Graphics Hardware: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
Graphics Driver:
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.11.0
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 6.0
Re: Multi Editor 3D does not open multiple models [message #689582 is a reply to message #689528] |
Mon, 27 June 2011 22:05 |
you have to drag the diagram onto the 3D scene. However, this is not
working at the moment... I must have changed something and broke this
unfortunately. I will have a look at this problem in the next days.
You have nothing missed, it seems to be my fault. I will reply here as
soon as I have fixed that problem.
Jens
Re: Multi Editor 3D does not open multiple models [message #689892 is a reply to message #689819] |
Tue, 28 June 2011 14:16 |
Oh, I'm really sorry... I changed some things lately, and obviously I've
forgotten to commit everything (mainly because it is not completely
finished). I have now committed everything, at least everything I was
aware of ;-) Could you try to update all projects and see if it is
working then?
Jens
On 28.06.11 14:37, New23D wrote:
> On updating to r587, AbstractMultiEditor3D.java in
> org.eclipse.gef3d.ext.multieditor has developed a problem on Line 229,
> "MultiEditorFigureFactory cannot be resolved to a type".
> Thank you for the quick update, nonetheless. This is a fantastic tool!
Re: Multi Editor 3D does not open multiple models [message #689971 is a reply to message #689915] |
Tue, 28 June 2011 16:56 |
On 28.06.11 17:25, New23D wrote:
> The build is fine now but back to the behaviour I reported - still opens
> a new tab for me. Is it working for you?
I have tested this with the multi ecore editor and Helios 3.6 (as the
UML tools are not available as of version 3.6), and with the uml multi
editor and Gallileo 3.5. It works in both cases.
You have to drop the diagram file (*.ecorediag, *.umlclass, *.umlact,
*.umlusc) onto the 3D canvas. That is, do not drop it onto the editor
tab or the editor area (such as the palette) outside the 3D canvas.
Also, ensure to open the first diagram with a multi editor (use Open
With...).
If it still is not working, you may create a small screencast (showing
how you drop a file) and attach this to a bug report in bugzilla. I can
then have a look at it.
Jens
FUDForum. Page generated in 0.02890 seconds
