Re: word in column cannot wrap [message #689441 is a reply to message #689172] |
Mon, 27 June 2011 16:03 |
Can you give some more detail? What version of BIRT are you using?
Jason
On 6/26/2011 11:49 PM, forums-noreply@eclipse.org wrote:
> as attached, I found the column is not width enough and the word cannot wrap, is this normal because the word has no space between?
> Or is it related to font problem? but I check that my rpt, the font property is empty, so I don't know what fonts my report is using!!
Re: word in column cannot wrap [message #689899 is a reply to message #689756] |
Tue, 28 June 2011 15:03 |
Do you want the text to wrap? The time stamp column appears to be
wrapping. If you do not want it to wrap try creating a style with the
text block whitespace set to nowrapping. I think this has been fixed in
later versions of BIRT. Also on the general properties of the report
you can change Layout Preference to Fixed Layout instead of Auto.
Jason
On 6/28/2011 5:43 AM, forums-noreply@eclipse.org wrote:
> version
> Eclipse BIRT Designer Version 2.2.1.r221_v20070924 Build
> <2.2.0.v20070924-1550
> generated using eclipse plugin birt viewer
FUDForum. Page generated in 0.03479 seconds
