Re: Databinding - Writable and the opposite path. [message #690919 is a reply to message #689103] |
Thu, 30 June 2011 12:21 |
Christophe Bouhier Messages: 937 Registered: July 2009 |
Anyone please?
On 26-06-11 22:17, Christophe Bouhier wrote:
> I am succesfully using a WritableValue to bind between UI widgets (i.e.
> various Radio buttons, whereby the selected button will be reflected in
> the WritableValue), and a model object in an indirect manner. This
> happens by registering a IValueChangeListener on the UI Widgets, which
> aggregates the value changes from several UI widgets and update the
> WritableValue. So far so good.
> I am however struggling to achieve the opposite, which is updating the
> UI widgets from the model value. The WritableValue doesn't seem to sync
> with the model value, and perhaps it shoudn't (It's a Writable after
> all), but what would be the pattern for updating the UI widgets?
> Do I need another binding with a change listener on the model
> IValueProperty? (and in similar fashion update the UI widgets through a
> value change listener on the property?).
> Thank You, Christophe
Re: Databinding - Writable and the opposite path. [message #691144 is a reply to message #691103] |
Thu, 30 June 2011 19:52 |
On 30-06-11 19:56, Barani Kumar wrote:
> Kindly paste your code here, for the better understanding of your problem..
Below is the part which syncs the various UI widgets to a Writable.
The UI widgets are 4 radio buttons, depending on the which one is
selected an object is created with some settings. This works fine.
My question is how do I achieve the opposite? (How do I set the radio
buttons from the Object received).
Thanks / Christophe
// The writable.
IObservableValue dataKindWritableValue = new WritableValue();
DatakindAggregate aggregate = new DatakindAggregate( dataKindWritableValue);
//4 observables which aggregate through a value change listener.
IObservableValue identifierObservable =
SWTObservables.observeSelection(btnIdentifier);
identifierObservable.addValueChangeListener(aggregate);
IObservableValue timestampObservable =
SWTObservables.observeSelection(btnTimestamp);
timestampObservable.addValueChangeListener(aggregate);
IObservableValue metricvaluepObservable = SWTObservables
..observeSelection(btnMetricValue);
metricvaluepObservable.addValueChangeListener(aggregate);
IObservableValue periodObservable = SWTObservables
..observeSelection(this.btnPeriod);
periodObservable.addValueChangeListener(aggregate);
// Model Observable
IEMFValueProperty datatypeValueProperty = EMFProperties
.value(MetricsPackage.Literals.MAPPING_COLUMN__DATA_TYPE);
IObservableValue dataTypeObservable =
datatypeValueProperty.observe(mxlsColumn);
// Binding
context.bindValue(dataKindWritableValue,
dataTypeObservable);
// Change listener, sets the the dataKindObservable.
private class DatakindAggregate implements IValueChangeListener,
IValidator {
private IObservableValue dataKindObservable;
boolean timestamp = false;
boolean identifier = false;
boolean value = false;
boolean period = false;
DatakindAggregate(IObservableValue dataKindObservable) {
this.dataKindObservable = dataKindObservable;
* (non-Javadoc)
* @see
* org.eclipse.core.databinding.observable.value.IValueChangeListener
* #handleValueChange
* (org.eclipse.core.databinding.observable.value.ValueChangeEvent)
public void handleValueChange(ValueChangeEvent event) {
System.out.println(event.getObservable());
Object newValue = event.diff.getNewValue();
if (event.getObservable() instanceof ISWTObservableValue) {
Control control = (Control) ((ISWTObservableValue) event
.getObservable()).getWidget();
System.out.println(control);
if (control.equals(btnIdentifier)) {
this.identifier = (Boolean) newValue;
if (control.equals(btnTimestamp)) {
this.timestamp = (Boolean) newValue;
if (control.equals(btnMetricValue)) {
this.value = (Boolean) newValue;
if (control.equals(btnPeriod)) {
this.period = (Boolean) newValue;
allSet();
// Set the value of the writable, using the options set by creating a
new object.
private boolean allSet() {
// Create the DataKindObject, actually only on save.
System.out.println("I T V P=" + identifier + timestamp + value + period);
DataKind dk = null;
if(period){
ValueDataKind vdk = MetricsFactory.eINSTANCE.createValueDataKind();
vdk.setValueKind(ValueKindType.PERIOD);
// Set more options.
dk = vdk;
if(identifier){
IdentifierDataKind idk =
MetricsFactory.eINSTANCE.createIdentifierDataKind();
//idk.setObjectKind(value)
dk = idk;
if(value){
vdk.setValueKind(ValueKindType.METRIC);
//vdk.setMetricRef(value)
dk = vdk;
if(timestamp){
vdk.setValueKind(ValueKindType.DATETIME);
dk = vdk;
dataKindObservable.setValue(dk);
return true;
FUDForum. Page generated in 0.03360 seconds
