Home » Eclipse Projects » Standard Widget Toolkit (SWT) » specifying custom XULRunner installation doesn't work
specifying custom XULRunner installation doesn't work [message #688828] Sat, 25 June 2011 22:11 Go to next message
Carlo Salinari is currently offline Carlo SalinariFriend
Member
I'm trying to open an SWT.MOZILLA browser widget to see if I can get a
working WebGL canvas in my swt-based application.
I'm under win 7 64 bit, eclipse indigo 32 bit, firefox 5.0.
The problem is that the Browser() constructor is picking up the wrong
XULRunner installation (i.e. not that of firefox 5.0), and I can't make
it pick the right one.
When I try to run the test program from the faq:
http://www.eclipse.org/swt/faq.php#printmozillapath
import org.eclipse.swt.SWT;
import org.eclipse.swt.browser.*;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.widgets.*;
public class DisplayMozillaVersion {
Device.DEBUG = true;
Display display = new Display();
Shell shell = new Shell(display);
System.out.println(">>>Snippet creating SWT.MOZILLA-style Browser");
try {
new Browser(shell, SWT.MOZILLA);
System.out.println(">>>succeeded");
} catch (Error e) {
System.out.println(">>>This failed with the following error:");
e.printStackTrace();
System.out.println("\n\nSnippet creating SWT.NONE-style
Browser");
try {
new Browser(shell, SWT.NONE);
} catch (Error e2) {
System.out.println(">>>This failed too, with the
following error:");
e2.printStackTrace();
display.dispose();
I get this output:
XULRunner path: C:\Program Files (x86)\Common Files\Adobe\Adobe
Contribute CS5\App\Configuration\Browsers\Mozilla Run Time
Libraries\dist\bin\xpcom.dll
>>>succeeded
If I try to specify a XULRunner at launch time:
http://www.eclipse.org/swt/faq.php#specifyxulrunner
>eclipse -vmargs -Dorg.eclipse.swt.browser.XULRunnerPath="C:/Program
Files (x86)/Mozilla Firefox"
it is ignored, and I get the same output as above.
If I add the line:
System.setProperty("org.eclipse.swt.browser.XULRunnerPath", "C:/Program
Files (x86)/Mozilla Firefox");
as the first one in the main method of DisplayMozillaVersion, I get the
following error:
XULRunner path: C:\Program Files (x86)\Mozilla Firefox\xpcom.dll
org.eclipse.swt.SWTError: XPCOM error -2147467261
at org.eclipse.swt.browser.Mozilla.error(Mozilla.java:2502)
at org.eclipse.swt.browser.Mozilla.initXPCOM(Mozilla.java:1902)
at org.eclipse.swt.browser.Mozilla.create(Mozilla.java:700)
at org.eclipse.swt.browser.Browser.<init>(Browser.java:96)
at snippets.Findzilla.main(Findzilla.java:16)
Snippet creating SWT.NONE-style Browser
>>>succeeded
What am I doing wrong?
Carlo
Re: specifying custom XULRunner installation doesn't work [message #689350 is a reply to message #688828] Mon, 27 June 2011 13:30 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
Hi Carlo,
The Browser control currently only embeds XULRunner versions < 2.0,
which means Firefox versions < 4.0. So there current isn't a way to do
this. The existing request for support of newer mozilla versions is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=327696 .
Grant
On 6/25/2011 6:11 PM, Carlo Salinari wrote:
> public static void main(String[] args) {
> try {
> } catch (Error e) {
> Browser");
> try {
> following error:");
> display.dispose();
> I get this output:
>>>> succeeded
> If I add the line:
> following error:
>>>> succeeded
> Carlo
Re: specifying custom XULRunner installation doesn't work [message #689389 is a reply to message #689350] Mon, 27 June 2011 14:42 Go to previous messageGo to next message
Member
On 6/27/2011 3:30 PM, Grant Gayed wrote:
> Hi Carlo,
I see, thanks for the pointer.
Is it much work to implement support for xulrunner >= 2?
Which parts of swt should be modified/updated?
Carlo
Re: specifying custom XULRunner installation doesn't work [message #689838 is a reply to message #689389] Tue, 28 June 2011 13:33 Go to previous message
This would be a bigger effort than previous xulrunner release catch-ups.
I believe this release contained many more interface changes than
previous ones, and may even require that a separate swt library be
shipped for it (I think this is the case because attempts to use
XULRunner 2.0 with the current swt library have crashed on the first C
call). I think that for this to be done it needs to appear as an
eclipse plan item with time allocated for it.
Grant
>> Hi Carlo,
>> The Browser control currently only embeds XULRunner versions< 2.0,
>> which means Firefox versions< 4.0. So there current isn't a way to do
> Is it much work to implement support for xulrunner>= 2?
> Carlo
Previous Topic:StackLayout Problem
Next Topic:Export jar for 32-bit Machine from 64-bit machine
Current Time: Sun May 16 23:44:20 GMT 2021
Powered by FUDForum. Page generated in 0.02054 seconds
