Re: [ATL] Copy Ecore Files.launch does not exist [message #69324 is a reply to message #69223] |
Wed, 12 December 2007 23:19 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
Hi Matthias,
> when I compile the ATL source code inside Eclipse, I get this error:
> Errors during build.
> Errors running builder 'Integrated External Tool Builder' on project
> 'org.eclipse.m2m.atl.engine'.
> Launch configuration Copy Ecore Files at
.....org.eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine/ .externalToolBuilders/Copy
> Ecore Files.launch does not exist.
> What's wrong?
Depending on how your eclipse workspace is setup, .ecore files from the
src/ folder are copied or not to the bin/ folder.
Now that we understand that, the best solution is probably to make sure
the workspace is setup properly.
However, before we understood that, a solution had to be found. It
consisted in using an ant script to copy the .ecore files, with a
corresponding "external builder".
Note that I do find the "Copy Ecore Files.launch" file on the Eclipse CVS:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine/.externa lToolBuilders/?root=Modeling_Project
You may have an incomplete checkout of the CVS.
In any case, now may be the time to switch to a simpler solution than
using this ant script :-).
Frédéric Jouault
Re: [ATL] Copy Ecore Files.launch does not exist [message #69745 is a reply to message #69607] |
Fri, 14 December 2007 21:32 |
Dennis Wagelaar Messages: 147 Registered: July 2009 |
Matthias Bohlen schreef:
> On 2007-12-13 00:19:03 +0100, Frédéric Jouault
>> CVS:
> Hi
> Frédéric,
> yes, I also find this file in my workspace. Maybe, the reason is that
> the file name contains spaces? My machine is a MacBook Pro running under
> Mac OS X.
No problems on my MBPro, so that's not it.
> If I understand you correctly, this external builder could be removed.
> Who could do this and when?
> Cheers
> Matthias
I'm also ok with removing it. I put it there initially, b.t.w., so I can
remove it too. I don't have much time before 15th January, though, so a
workaround is in order:
- Select your project in the Package Explorer (or similar)
- Select "Project -> Properties" from the menu
- Select "Builders" in the list on the left
- Uncheck "Copy Ecore Files"
Dennis
FUDForum. Page generated in 0.05306 seconds
