Eugenia won't install (easily) in Indigo because Indigo does not include GMF SDK [message #688261] |
Fri, 24 June 2011 09:38 |
Originally posted by: jendrik.johannes
Hi guys,
I just wanted to let you know:
I just tried to install Eugenia from Epsilon's update site in Indigo
(tried both stable and interim). I always got the following dependency
problem:
"Missing requirement: Epsilon Eugenia (Incubation) 0.9.0.201106111013
(org.eclipse.epsilon.eugenia.feature.feature.group 0.9.0.201106111013)
requires 'org.eclipse.gmf.map 0.0.0' but it could not be found"
After digging into this I found out that the GMF SDK is not included in
Indigo (what the ... ???). If you add the GMF update site, it works:
http://download.eclipse.org/modeling/gmf/update-site/releases/
Unfortunately, this also adds a bunch of other update sites (including a
not existing one) which is a bit annoying.
Anyway, you might consider to configure an 'associateSites.xml' for the
Epsilon update sites that does configure the GMF update site automatically.
Jendrik
Re: Eugenia won't install (easily) in Indigo because Indigo does not include GMF SDK [message #688329 is a reply to message #688261] |
Fri, 24 June 2011 13:02 |
Hi Jendrik,
Many thanks for bringing this to our attention and for suggesting a solution! Incidentally this was something we were discussing yesterday with Antonio and Louis after I tried to install Epsilon atop Indigo. Perhaps not including GMF in the "Install modelling components" wizard is an oversight that may be fixed in SR-1 but we'll definitely chase this with the GMF developers and the Modelling PMC to find out exactly what's happening.
Dimitris
FUDForum. Page generated in 0.02884 seconds
