Re: PHP Syntax highlighting not showing in Svn repository exploring [message #688359 is a reply to message #688145] |
Fri, 24 June 2011 14:05 |
Lance E Sloan Messages: 7 Registered: July 2009 |
Ben K wrote on Thu, 23 June 2011 22:57I use eclipse pdt, eclipse helios sr2 (eclipse 3.6.2, pdt 2.2.1, subclipse 1.6.18, svn javahl 1.6.17 )
Syntax highlighting for php files works fin in php perspective, but in svn repository exploring perspective php files are not color coded.
Quote:double clicking on a php file to show the repository version just shows as a plain text files.
I've never tried this feature before, but now that I have, I can see it's very useful. I see the problem with syntax highlighting, too.
I'm using Helios SR2, but with slightly older versions of the Subversion extensions (Subclipse 1.6.17, SVN JavaHL 1.6.15).
I would really like to know how to enable the syntax highlighting, too.
I've noticed that code-folding is enabled. If I hover the pointer over the "+" sign beside a folded PHP function, a panel appears that shows the code with syntax highlighted. If I keep this view of the file from SVN open and switch back to the PHP perspective, the highlighting doesn't change.
FUDForum. Page generated in 0.02634 seconds
