Home » Modeling » TMF (Xtext) » xbase2 - formatting line breaks
xbase2 - formatting line breaks [message #688035] Thu, 23 June 2011 18:27 Go to next message
Erik Nijkamp is currently offline Erik NijkampFriend
Hey folks,
I'm fighting with the xbase2 formatter.
This is what I currently have:
@SuppressWarnings("restriction")
public class FooScriptDslFormatter extends XbaseFormatter
    protected void configureFormatting(FormattingConfig c)
        // xbase
        FooScriptDslGrammarAccess f = (FooScriptDslGrammarAccess) getGrammarAccess();
        configure(c, f.getXbaseGrammarAccess());
Unfortunately this does not trigger line breaks for XFeatureCalls:
a() b() c()
Should be transformed to:
a()
b()
c()
Note that we don't want to introduce semicolons. Hence I was not able to determine the correct element for the setLinewrap() invocation.
Do I have to dig deeper or can we play a simple trick here?
Thanks!
erik
Re: xbase2 - formatting line breaks [message #692622 is a reply to message #688035] Mon, 04 July 2011 20:59 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Erik,
IIRC there is no linewrap configured for XFeatureCalls. There will be a
linewrap inside of XBlockExpressions for each expression. Is your list
of feature calls an XBlockExpression (which is acutally instantiated by
the ParserRule XBlockExpression from the XbaseGrammar)?
Sebastian
On 23.06.11 20:27, Erik Nijkamp wrote:
> Hey folks,
> @Override
> // xbase
> getGrammarAccess();
> a() b() c()
> a()
> b()
> c()
> Thanks!
> erik
Re: xbase2 - formatting line breaks [message #901316 is a reply to message #688035] Fri, 10 August 2012 18:24 Go to previous messageGo to next message
Nikola Petrov is currently offline Nikola PetrovFriend
I am having the same problem and I am using the XBlockExpression ParserRule for my xbase support. I have described the problem as a subpost here with a minimal grammar.
Were you able to fix it after all and if yes how?
[Updated on: Fri, 10 August 2012 18:25]
Report message to a moderator
Re: xbase2 - formatting line breaks [message #901584 is a reply to message #688035] Mon, 13 August 2012 14:18 Go to previous message
It seems this is not properly implemented for the xblockexpression as far as I could see it in the code. Here is the code that provides a nice formatting for me.
	 * Some code taken from the Spray project style formatter</a>
	private void configureXBase(FormattingConfig c, XbaseGrammarAccess grammar) {
		for (Pair<Keyword, Keyword> kw : grammar.findKeywordPairs("{", "}")) {
			c.setLinewrap().after(kw.getFirst());
			c.setLinewrap().around(kw.getSecond());
			c.setIndentation(kw.getFirst(), kw.getSecond());
		// no space before comma, one space after
		for (Keyword kw : grammar.findKeywords(",")) {
			c.setNoSpace().before(kw);
			c.setSpace(" ").after(kw);
		c.setNoSpace().around(
				grammar.getStaticQualifierAccess().getColonColonKeyword_1());
		xbaseFormmater.configureXMemberFeatureCall(c,
				grammar.getXMemberFeatureCallAccess());
		xbaseFormmater.configureXParenthesizedExpression(c,
				grammar.getXParenthesizedExpressionAccess());
		c.setLinewrap().after(grammar.getXExpressionInsideBlockRule());
		Keyword semicolon = grammar.getXBlockExpressionAccess()
				.getSemicolonKeyword_2_1();
		c.setNoLinewrap().before(semicolon);
		c.setNoSpace().before(semicolon);
		c.setLinewrap().after(semicolon);
where xbaseFormmater is an instance of XbaseFormatter which you can inject easily with guice.
Previous Topic:Creating typrefs for bounded wildcards
Next Topic:Method createSequence is exceeding 65535
Current Time: Sun Jun 20 17:23:07 GMT 2021
Powered by FUDForum. Page generated in 0.02394 seconds
