Use of ^-Operator [message #69035] |
Thu, 19 March 2009 18:51 |
Timothy Marc Messages: 547 Registered: July 2009 |
Hi all,
what is the general use of the message operator ^. I can specify in an
post condition, that the message was called within the execution of an
operation, but that makes only sense in the context of any behavioral
aspects like activity diagrams or interaction, or am i wrong? I'm a
little bit confused, how an OCL engine could check, whether an operation
was called?
Imho, the one and only situation in which this is possible is for
example in an interaction, where you can call the operation, specified
in the ^-Operator, wihtin the BehaviorExecution of the Operation, that
calls the other operation.
So, am i right, that this message operators only make sense in context
of behavior specification, as well as the whole state machine concepts
of ocl only make sense in the context of an UML state machine?
Thx
Timothy
Re: Use of ^-Operator [message #69120 is a reply to message #69035] |
Fri, 20 March 2009 00:51 |
Originally posted by: give.a.damus.gmail.com
Hi, Timothy,
I have seen the message assertion used more often as an oblique way of
specifying an operation's algorithm than in any other capacity. I don't
know what expectation there may be that a tool would implement
evaluation of these expressions, but as you surmise (and I agree), it
could be challenging to do it efficiently.
I can imagine that a technology such as AspectJ, with its support for
control flows and call chains, could be employed in an implementation.
In an environment like OSGi, one could even weave in such constraints
and weave them out again on the fly.
The message expressions are most naturally used, I suppose, in the
postconditions of behavioral specifications (such as Operations and
Behaviors) but they could also be employed in trigger guards. In an
invariant context I think they would make less sense.
HTH,
Christian
Timothy Marc wrote:
> Hi all,
> was called?
> Thx
> Timothy
FUDForum. Page generated in 0.02996 seconds
