(no subject) [message #687827] |
Thu, 23 June 2011 09:52 |
Koen Aers Messages: 16 Registered: July 2009 |
I launching a Java application using the
org.eclipse.debug.core.ILaunchConfiguration.launch(...). When trying to
test this piece of code in a JUnit test I get a green result.
However, I also get the following nasty exception:
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.debug.ui was
unable to load class org.eclipse.debug.internal.ui.sourcelookup.Prompter.
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at
org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at
org.eclipse.debug.core.DebugPlugin.getStatusHandler(DebugPlugin.java:584)
at
org.eclipse.debug.core.model.LaunchConfigurationDelegate.saveBeforeLaunch(LaunchConfigurationDelegate.java:252)
at
org.eclipse.debug.core.model.LaunchConfigurationDelegate.preLaunchCheck(LaunchConfigurationDelegate.java:208)
at
org.eclipse.jdt.launching.AbstractJavaLaunchConfigurationDelegate.preLaunchCheck(AbstractJavaLaunchConfigurationDelegate.java:921)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:809)
This exception is apparently caused by the fact that there is no workbench:
Caused by: java.lang.IllegalStateException: Workbench has not been
created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
at
org.eclipse.debug.internal.ui.contextlaunching.LaunchingResourceManager.startup(LaunchingResourceManager.java:546)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.getLaunchingResourceManager(DebugUIPlugin.java:306)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlugin.java:507)
It seems that the launch configuration is trying to start the
DebugUIPlugin. Is there any reason for this dependency on UI code?
By the way, I was able to suppress the exception by embedding the test
code in a UIJob, but I think it is a pity I have to add this dependency
on org.eclipse.ui.workbench for no apparent reason.
Can somebody enlighten me?
Koen
FUDForum. Page generated in 0.04555 seconds
