Home » Modeling » EMF » Common editor for model + model extension
Common editor for model + model extension [message #687522] Tue, 21 June 2011 08:51 Go to next message
Sebastian Fuchs is currently offline Sebastian FuchsFriend
Member
I have an Ecore Model 1 of type
AbstractChild
MyContainer
- children : AbstractChild
I have a second Model 2 in a different plugin extending Model 1 declaring
ConcreteChild->AbstractChild
I have generated a default Editor for Model 1 and Model 2 but did not
manage to see "add ConcreteChild" in the Context Menu of a
MyContainer-instance.
How can I easily create one common Editor, even if there is a growing
number of extending model plugins ?
Sebastian
Re: Common editor for model + model extension [message #687523 is a reply to message #687522] Tue, 21 June 2011 09:19 Go to previous messageGo to next message
Originally posted by:
On 21.06.11 10.51, Sebastian Fuchs wrote:
> Hello,
> AbstractChild
> MyContainer
There's an extension point that is used for this purpose, i.e. let other
plugins contribute child creation actions for additional subclasses.
However, when you generate the base editor, you must enable it by
setting the Child Creation Extenders option (Edit category) of the
EPackage genmodel element to true.
Hallvard
Re: Common editor for model + model extension [message #687525 is a reply to message #687523] Tue, 21 June 2011 14:13 Go to previous messageGo to next message
Member
Thank you Hallvard,
that works for me.
I found the corresponding article knowing the correct key words now:
http://ed-merks.blogspot.com/2008/01/creating-children-you-didnt-know.html
Unfortunatelly the extension was not created automatically for my
existing projects so i had to try myself around with sample projects
from the scratch.
The extension I manually had to make is:
<extension
point="org.eclipse.emf.edit.childCreationExtenders">
<extender
class="de.tragwerk.solution.statics.combination.ui.kombinationUi.provider.KombinationUiItemProviderAdapterFactory$EditorChildCreationExtender"
uri="http://www.tragwerk-software.de/solution/editor">
</extender>
</extension>
which must be declared at the extending edit plugin.
Sebastian
Am 21.06.2011 11:19, schrieb Hallvard Trætteberg:
>> Hello,
>> AbstractChild
>> MyContainer
> Hallvard
Re: Common editor for model + model extension [message #687533 is a reply to message #687525] Wed, 22 June 2011 07:39 Go to previous message
On 21.06.11 16.13, Sebastian Fuchs wrote:
> Thank you Hallvard,
> that works for me.
> from the scratch.
Yes, EMF does not overwrite or edit plugin.xml if it already exists.
This is a long-standing problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=150092
I think that EMF at least should generate a plugin_gen.xml, to help the
user merge by hand.
Hallvard
Previous Topic:&quot;Stale&quot; attribute values on a proxy
Next Topic:[CDO] access CDO server in same JVM like CDO Sessions view
Current Time: Mon Jun 01 00:11:06 GMT 2020
Powered by FUDForum. Page generated in 0.01966 seconds
