Home » Modeling » EMF » (no subject)
(no subject) [message #687469] Wed, 15 June 2011 07:11
While committing a rather large transaction, we receive the following
Timeout on the CDO Server.
Any idea what causes this problem? And how I can prevent it?
Greetings,
-- Carel
!ENTRY org.eclipse.emf.cdo.server 1 0 2011-06-15 09:13:06.344
!MESSAGE CDO server started
!ENTRY org.eclipse.net4j 4 0 2011-06-15 11:28:25.648
!MESSAGE TimeoutException
!STACK 0
java.util.concurrent.TimeoutException
org.eclipse.net4j.util.io.IOTimeoutException.createTimeoutException(IOTimeoutException.java:46)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:255)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.eclipse.net4j.util.io.IOTimeoutException
org.eclipse.net4j.buffer.BufferInputStream.ensureBuffer(BufferInputStream.java:203)
org.eclipse.net4j.buffer.BufferInputStream.read(BufferInputStream.java:109)
at java.io.InputStream.read(Unknown Source)
at java.io.DataInputStream.readFully(Unknown Source)
at java.io.DataInputStream.readUTF(Unknown Source)
org.eclipse.net4j.util.io.ExtendedIOUtil.readString(ExtendedIOUtil.java:197)
org.eclipse.net4j.util.io.ExtendedDataInputStream.readString(ExtendedDataInputStream.java:36)
org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readString(ExtendedDataInput.java:135)
org.eclipse.net4j.util.io.StringCompressor.readString(StringCompressor.java:330)
org.eclipse.net4j.util.io.StringCompressor.read(StringCompressor.java:175)
org.eclipse.emf.cdo.internal.common.protocol.CDODataInputImpl.readCDOPackageURI(CDODataInputImpl.java:141)
org.eclipse.emf.cdo.common.model.CDOClassifierRef.<init>(CDOClassifierRef.java:77)
org.eclipse.emf.cdo.internal.common.protocol.CDODataInputImpl.readCDOClassifierRef(CDODataInputImpl.java:146)
org.eclipse.emf.cdo.internal.common.protocol.CDODataInputImpl.readCDOClassifierRefAndResolve(CDODataInputImpl.java:151)
org.eclipse.emf.cdo.internal.common.revision.delta.CDORevisionDeltaImpl.<init>(CDORevisionDeltaImpl.java:122)
org.eclipse.emf.cdo.internal.common.protocol.CDODataInputImpl.readCDORevisionDelta(CDODataInputImpl.java:449)
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:175)
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:91)
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:84)
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:326)
org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:63)
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
... 4 more
!ENTRY org.eclipse.emf.cdo.server 4 0 2011-06-15 11:28:43.456
!MESSAGE Timeout after 10001 millis
!STACK 0
org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Timeout after
10001 millis
org.eclipse.net4j.util.om.monitor.TimeoutMonitor.handleTimeout(TimeoutMonitor.java:121)
org.eclipse.net4j.util.om.monitor.TimeoutMonitor$1.handleTimeout(TimeoutMonitor.java:61)
at org.eclipse.net4j.util.concurrent.Timeouter$1.run(Timeouter.java:87)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
Previous Topic:(no subject)
Next Topic:Reuse Modisco's genmodel
Current Time: Sun Nov 02 11:58:48 EST 2025
Powered by FUDForum. Page generated in 0.54958 seconds
