Home » Modeling » EMF » (no subject)
(no subject) [message #687232 is a reply to message #687229] |
Fri, 17 June 2011 07:16 |
Am 16.06.2011 23:53, schrieb Martin Taal:
> As an extra info, I tried adding a listener to the container for the event that the repository was added, but when execute on that (and connect to the repository on that event) then I get a stackoverflowerror. So that does not seem to be a good direction either.
Hmm, I would have suggested that an IListener on the container is preferrable over an IElementProcessor. In both cases you should check isActive() on the added container element (your repository) and if it's not yet active add another listener (LifecycleEventAdapter) to that element and postpone your processing. If yu submit a bugzilla I can abstract this pattern in a new ActivationAdapter class because this looks like a common use case.
Cheers
/Eike
http://www.esc-net.de
> gr. Martin
> On 06/16/2011 11:26 PM, Martin Taal wrote:
>> Hi,
>> I have some server side code which starts a job which runs on the server and connects to the CDO server. This job should
>> start when the whole osgi app starts but it should get a signal when the repository is ready to connect to. When it gets
>> the signal it can start itself and read info from the repository. Is there a way to receive this signal?
>> I tried an element post processor but at that point the repository has been created but is not yet available to be used
>> through normal cdo session/transaction.
Cheers
/Eike
(no subject) [message #687511 is a reply to message #687229] |
Cheers
/Eike
> gr. Martin
>> Hi,
Cheers
/Eike
(no subject) [message #687516 is a reply to message #687232] |
Fri, 17 June 2011 09:27 |
Okay, I will try to add a listener directly to the container. Where do I that? Or can it be done declaratively?
gr. Martin
>> Hi,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> gr. Martin
>>> Hi,
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
(no subject) [message #687520 is a reply to message #687516] |
Fri, 17 June 2011 20:03 |
Am 17.06.2011 11:27, schrieb Martin Taal:
Only programmatically I fear:
IPluginContainer.INSTANCE.addListener(new IListener() {...});
I like the idea of being able to do it declaratively, though. Can you file a bugzilla to remind me?
Cheers
/Eike
> gr. Martin
>>> Hi,
>> Cheers
>> /Eike
>>> gr. Martin
>>>> Hi,
Cheers
/Eike
Current Time: Wed Apr 24 23:57:40 GMT 2024
Powered by FUDForum. Page generated in 0.03274 seconds
