Home » Modeling » EMF » model myself an EBooleanObject
Re: model myself an EBooleanObject [message #687185 is a reply to message #687183] |
Sun, 12 June 2011 16:22 |
Ed Merks Messages: 33137 Registered: July 2009 |
Comments below.
exquisitus wrote:
> What to you mean with "back"?
It starts out as null, right, so you'd be setting it back to the
original default value.
> do you refer to the "Ecore Diagram Editing" editor or the "Sample
> Ecore Model Editor" or the "Sample Reflective Edore Model Editor" (by
> the way, what is the diff between the last two?)?
I'm referring to the generated editor for your model. The Sample Ecore
Model Editor is for editing instances of Ecore, e.g., *.ecore files, the
Sample Reflective Ecore Model Editor is for editing instances of any
arbitrary model, e.g., Library instances stored *.library files.
> > There's a reset button in the properties view for setting the back to
> > null. You can also look at the EMF recipes in the wiki for how to
> define
> > your own specialized editor.
> > exquisitus wrote:
> >> I not managed to model a EDataType which behaves as EBooleanObject,
> >> e.g. having the possible values true,false and null. Anybody knows how
> >> to achieve this with the ecore editor?
Ed Merks
Re: model myself an EBooleanObject [message #687187 is a reply to message #687185] |
Mon, 13 June 2011 04:59 |
John Smith Messages: 137 Registered: July 2009 |
I also mean how to do my task with the Ecore editor, not the generated
editor. I want to edit the Ecore file, but dont know how to achieve my
goal. I copied from Ecore.ecore the following into my ecore metamodel:
<eClassifiers xsi:type="ecore:EDataType" name="EBooleanObject"
instanceClassName="java.lang.Boolean">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="baseType" value="EBoolean"/>
<details key="name" value="EBoolean:Object"/>
</eAnnotations>
</eClassifiers>
So I not named it "EBooleanObject" but "LOGICAL". However my datatype
not behaves as EBooleanObject, since I can store only the state true and
false, not the state true, false and null. So EBooleanObject finally
supports 4 states:
true
false
null
not-set
My plagiarism supports only 3 states
true
false
not-set
So I cannot store "null", what did I miss?
Background: for some reasons, I do not want to use EBooleanObject
directly in my metamodel but an own datatype. But I will end up using it
directly if I can not find out how to do a EBooleanObject plagiarism.
Re: model myself an EBooleanObject [message #687188 is a reply to message #687187] |
Mon, 13 June 2011 10:54 |
Comments below.
> the
> editor.
In that case, what you see is all you get. If you want more, you'd need
to do what I mentioned in the recipe in the wiki.
> I want to edit the Ecore file, but dont know how to achieve my goal. I
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> and false, not the state true, false and null. So EBooleanObject
> finally supports 4 states:
> true
> false
> null
> not-set
Only if your feature is unsettable (which has nothing to do with the
type). You've not mentioned whether that's the case or not.
> true
> false
> not-set
So then you want an unsettable feature of type boolean or a plain old EEnum.
The problem is whether it's null that's really important or whether it's
having a third state that's important; you decide that.
And why might that be?
> But I will end up using it directly if I can not find out how to do a
If you need to specialize anything, you'll need to do it via code in a
specialized editor.
Ed Merks
Re: model myself an EBooleanObject [message #687192 is a reply to message #687188] |
Tue, 14 June 2011 02:09 |
I think I have identifier the source of error.
TBooleanObject is handled by CDO in special by CDOTypeImpl.BOOLEAN_OBJECT
But my EBooleanObject plagiarism is handled by CDOTypeImpl.CUSTOM.
So while CDOTypeImpl.BOOLEAN_OBJECT not tries to convert NIL to a string
representation, CDOTypeImpl.CUSTOM does it, resulting in something like
e.g. "Object@123" (which is NIL.toString()).
Later, when I retrieve the attribute value, in comes down to an
invocation of java.lang.Boolean.valueOf("Object@123"), which returns
false, so thats why the null-value is mapped to false for my plagiarism.
I am not familiar with CDO, its the question now if CDO is really
required to handle EBooleanObject in special, or should it handle it
like a user-defined EDataType? So dont know if its a CDO bug or not,
what do you think, Ed?
Re: model myself an EBooleanObject [message #687198 is a reply to message #687192] |
Tue, 14 June 2011 12:53 |
I'm having a hard time following this thread. I can't comment on
details of CDO's implementation. That's a question for Eike, but I'm not
sure he understands how you arrived at this point...
> string representation, CDOTypeImpl.CUSTOM does it, resulting in
> something like e.g. "Object@123" (which is NIL.toString()).
Ed Merks
Re: model myself an EBooleanObject [message #687438 is a reply to message #687178] |
Sat, 11 June 2011 17:02 |
define your own specialized editor.
Ed Merks
Re: model myself an EBooleanObject [message #687442 is a reply to message #687183] |
Comments below.
> define
Ed Merks
Re: model myself an EBooleanObject [message #687445 is a reply to message #687185] |
<eAnnotations
</eAnnotations>
</eClassifiers>
supports 4 states:
true
false
null
not-set
true
false
not-set
Re: model myself an EBooleanObject [message #687446 is a reply to message #687187] |
Comments below.
> the
> editor.
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> true
> false
> null
> not-set
> true
> false
> not-set
specialized editor.
Ed Merks
Re: model myself an EBooleanObject [message #687452 is a reply to message #687188] |
Re: model myself an EBooleanObject [message #687461 is a reply to message #687192] |
Ed Merks
Current Time: Sat Apr 20 03:53:17 GMT 2024
Powered by FUDForum. Page generated in 0.04839 seconds
