Home » Modeling » EMF » converting EXPRESS to ECORE: derived attribute
converting EXPRESS to ECORE: derived attribute [message #687123] Thu, 02 June 2011 07:49 Go to next message
John Smith is currently offline John SmithFriend
in EXPRESS (some old metametamodell used in architecture) it is possible
to define an attribute A in class X, and set it as derived in class Y
which derives from class X. Ecore cannot redefine modifiers in derived
classes, any idea to model this with Ecore nevertheless?
Re: converting EXPRESS to ECORE: derived attribute [message #687132 is a reply to message #687123] Thu, 02 June 2011 14:17 Go to previous messageGo to next message
Likely Ed Willink will suggest using UML which supports a kind of
redefinition and maps it to Ecore via EAnnotation. What are you hoping
to accomplish by marking it as derived? There's not so much impact of
doing that; EcoreUtil.copy won't copy it (though it knows nothing about
UML's EAnnotations, so that won't help).
exquisitus wrote:
> possible to define an attribute A in class X, and set it as derived in
> class Y which derives from class X. Ecore cannot redefine modifiers in
> derived classes, any idea to model this with Ecore nevertheless?
Ed Merks
Re: converting EXPRESS to ECORE: derived attribute [message #687135 is a reply to message #687132] Fri, 03 June 2011 02:10 Go to previous messageGo to next message
> What are you hoping
As I currently know WHAT the derived values are, I explicitely assign
the derive values when an instance of the subtype is created. The
disadvantage of this approach is that the assigned values get stored in
a database for example. So e.g. I thought about overwriting getA() in
AImpl and return the derived values there. I dont know if this is
compatible with CDO if I just add a getA() method in an Impl class,
since CDO retrieves the values for features reflectively, not calling
the getters I think.
Re: converting EXPRESS to ECORE: derived attribute [message #687136 is a reply to message #687135] Fri, 03 June 2011 04:38 Go to previous message
Comments below.
> > What are you hoping
So we're just talking about different defaults. That has nothing to do
with derived in these sense that Ecore uses; i.e., it's not a value
that's computed from other values and therefore would never need to be
copied.
> The disadvantage of this approach is that the assigned values get
> stored in a database for example.
Because eIsSet is considered true.
> So e.g. I thought about overwriting getA() in AImpl and return the
Yes, probably better.
> I dont know if this is compatible with CDO if I just add a getA()
> method in an Impl class, since CDO retrieves the values for features
> reflectively, not calling the getters I think.
It depends on whether you use reflective delegation (getA would get
called) or dynamic delegation (it's more efficient and doesn't call getA).
Ed Merks
Re: converting EXPRESS to ECORE: derived attribute [message #687369 is a reply to message #687123] Thu, 02 June 2011 14:17 Go to previous message
exquisitus wrote:
Ed Merks
Re: converting EXPRESS to ECORE: derived attribute [message #687372 is a reply to message #687132] Fri, 03 June 2011 02:10 Go to previous message
> What are you hoping
Re: converting EXPRESS to ECORE: derived attribute [message #687373 is a reply to message #687135] Fri, 03 June 2011 04:38 Go to previous message
Comments below.
> > What are you hoping
copied.
Ed Merks
Previous Topic:[CDO] License acceptance is preventing install
Next Topic:Re: [Teneo] MySQL does not create new tables on init
Current Time: Sun Sep 20 08:51:34 GMT 2020
Powered by FUDForum. Page generated in 0.02467 seconds
