Home » Modeling » EMF » Delegates for creating instances of data types
Delegates for creating instances of data types [message #687091] |
Sun, 29 May 2011 15:18 |
Originally posted by:
I've been using EMF delegates for some time and they are great for
interactively enriching a model with Javascript or OCL. There is one
thing I miss, however, and that is the ability to create instances of an
EDataType. This should allow creating an instance from a String and
converting it back, using two expressions (or body statements) in
appropriate annotations. This kind of delegate should used by the
standard factory, so you have the choice of either adding the
annotations or generating and implementing the createXXXFromString and
convertXXToString.
If this makes sense, I can try to implement it and submit the code for
review by the EMF team.
Hallvard
Re: Delegates for creating instances of data types [message #687093 is a reply to message #687092] |
Sun, 29 May 2011 20:46 |
On 29.05.11 17.56, Ed Willink wrote:
> Do you mean that you want to be able to program the body of e.g.
> convertXXToString in the Ecore model?
> FromString is specific to EDataType which cannot have a special
> operation so I guess it just needs to be an agreed EAnnotation.
> ToString is more general; you might allow customisation of toString for
> all EClassifiers, but again I guess it just needs to be an agreed
> EAnnotation.
Yes, the idea is to define two annotations for an EDataType, one for the
body of convertXXXToString and one for the body of createXXXFromString
(similar to the annotation for an EOperation body). Then you can use
your favorite scripting language (currently OCL and very soon
Javascript) to support custom EDataTypes without generating the factory
code and implementing it in Java.
> You need to check the UML2Ecore conversion carefully because there is a
> surprising amount of generation capability for UML and you might find
> that what you want is already more than 90% implemented.
I'm not using UML, hence I want Ecore to support it directly.
Hallvard
Re: Delegates for creating instances of data types [message #687096 is a reply to message #687095] |
Mon, 30 May 2011 08:51 |
On 30.05.11 09.09, Ed Willink wrote:
> I'm not suggesting that you use UML, just understand the EAnnotations
> that UML2Ecore already uses so that you avoid another duplication
> similar to that by the EMF invocation delegate annotation of the
> GenModel operation body annotation.
You mean we should reuse an eAnnotation source and key pair if this is
already somehow supported by UML2Ecore, to avoid getting yet another
pair. Perhaps someone with knowledge about this can tell us if this is
the case?
> I'm planning to get direct OCL to Java generation going in an
> intermediate OCL 3.2 release. This will cut out the parsing overheads
> and much of the run-time dispatch overheads by directly calling the OCL
> library operations. This needs integration with genmodel. Perhaps it is
> similar to something you need.
Not at this point, but could be in the future.
Hallvard
Re: Delegates for creating instances of data types [message #687097 is a reply to message #687094] |
Mon, 30 May 2011 09:12 |
On 30.05.11 03.21, Ed Merks wrote:
> It does make sense. Ideally we'd have something that even works for
> dynamic models. Of course there is already reflective support that looks
> for a String constructor (or valueOf method) and calls toString, but if
> it's a class over which you have no control, that doesn't really help.
E.g. java.net.URI has a static create method.
I have create this bugzilla and attached to it an experimental
implementation that works with js4emf:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=347611
Hallvard
Re: Delegates for creating instances of data types [message #687098 is a reply to message #687096] |
Mon, 30 May 2011 09:37 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Hallvard
> the case?
Most, perhaps all, of the Ecore annotations are described in the EMF
book, but the EMF delegates are not and the UML annotations are not.
I think someone, ?? you ??, would be doing a great service by greping
all *.jet* files in EMF and UML2 for anything that looks like an
EAnnotation source, and then creating a wiki page mapping source URI to
genmodel functionality. We could then retrofit reference documentation
and API contracts on what each EAnnotation source URI means, rather than
rely on examples of how to solve XSD and UML problems.
Ed Willink
Re: Delegates for creating instances of data types [message #687102 is a reply to message #687101] |
Mon, 30 May 2011 15:25 |
On 30.05.11 17.06, Ed Merks wrote:
> We could add reflective support for more common patterns; it doesn't
> seem likely thought that we could cover them all.
In many cases, there isn't an natural/obvious text format, so you'll
have to invent one for the sake of the model. That's why a pluggable
delegate makes sense. I hope someone has time to look at the attachment.
I could take it further, e.g. make a complete patch, but I would like an
evaluation of the current suggestion first.
Hallvard
Re: Delegates for creating instances of data types [message #687311 is a reply to message #687092] |
> EAnnotation.
Hallvard
Re: Delegates for creating instances of data types [message #687312 is a reply to message #687093] |
Mon, 30 May 2011 01:21 |
Ed Merks Messages: 33141 Registered: July 2009 |
Hallvard,
looks for a String constructor (or valueOf method) and calls toString,
but if it's a class over which you have no control, that doesn't really
help.
>> EAnnotation.
> the body of convertXXXToString and one for the body of
> createXXXFromString (similar to the annotation for an EOperation
> body). Then you can use your favorite scripting language (currently
> OCL and very soon Javascript) to support custom EDataTypes without
> generating the factory code and implementing it in Java.
> Hallvard
Ed Merks
Re: Delegates for creating instances of data types [message #687319 is a reply to message #687095] |
the case?
Hallvard
Re: Delegates for creating instances of data types [message #687320 is a reply to message #687094] |
Hallvard
Re: Delegates for creating instances of data types [message #687321 is a reply to message #687096] |
Hi Hallvard
> the case?
Ed Willink
Re: Delegates for creating instances of data types [message #687326 is a reply to message #687097] |
Mon, 30 May 2011 15:06 |
Hallvard,
> Hallvard
Ed Merks
Re: Delegates for creating instances of data types [message #687327 is a reply to message #687101] |
Hallvard
Current Time: Thu Apr 25 15:14:34 GMT 2024
Powered by FUDForum. Page generated in 0.04329 seconds
