Re: [QVT ] example problem [message #68956 is a reply to message #68895] |
Tue, 11 December 2007 18:41 |
Hi, Gary,
It looks like you are missing the MDT OCL feature(s).
http://www.eclipse.org/modeling/mdt/downloads/?project=ocl
Christian
Gary Leask wrote:
> I downloaded the QVT project m2m-qvto-SDK-incubation-1.0M1.zip and tried
> to load the example and I get the Error
> java.lang.NoClassDefFoundError: org/eclipse/ocl/cst/CSTNode
> at
org.eclipse.m2m.qvt.oml.editor.ui.QvtConfiguration.getHyperl inkDetectors(QvtConfiguration.java:153)
> at
org.eclipse.jface.text.source.SourceViewer.configure(SourceV iewer.java:391)
> at
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:3201)
> at
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
> at
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:378)
> at
org.eclipse.m2m.qvt.oml.editor.ui.QvtEditor.createPartContro l(QvtEditor.java:157)
> Am I missing some required plugins and where do I get them.
Re: [QVT ] example problem [message #68997 is a reply to message #68977] |
Tue, 11 December 2007 20:44 |
Hi, Gary,
The QVTo component is developing on the 1.2 release of MDT OCL, not the 1.1
release.
The 1.2 M3 build or a later integration build of OCL should work for you.
Christian
Gary Leask wrote:
> Christian,
> It looks the CSTNode class in this latest version of the ocl has been
> repackaged in an internal package org\eclipse\ocl\internal\cst
> The project still won't load.
> Gary
Re: [QVT ] example problem [message #69140 is a reply to message #69098] |
Wed, 12 December 2007 16:19 |
Hi, Gary,
OCL 1.2 requires EMF 2.4. It has a narrow (minor-version) dependency on EMF
because the OCL metamodel binding for Ecore extends the Ecore metamodel.
cW
Gary Leask wrote:
> Christian,
> This is probably a stupid question but I'm using
> Eclipse 3.3
> EMF 2.3
> UML 2.1
> Do I need to move to the latest (i.e. Eclipse 3.4, EMF 2.4) to use OCL 1.2
> or will it work with what I have?
> Thanks
> Gary
FUDForum. Page generated in 0.04372 seconds
