(no subject) [message #686486 is a reply to message #686434] |
Wed, 22 June 2011 10:37 |
This is indeed a bug which has not been fixed.
As a workaroundm you should try to find out the template file in
org.eclipse,gmf,codegin that is responsible for deducing the name of the
Interface from the domain type, modify it, and use it during your code
generation.
Please append your progress to bug 317241 so that it will be easier for
fix definitely.
On 22/06/2011 10:45, Andres Alvarez Mattos wrote:
> Diagram generation does not respect the Interface Name Pattern supplied
> in genmodel ?
> With custom 'Class Name Pattern' and 'Interface Name Pattern' properties
> in the genmodel, the generated GMF code has compilation errors because
> it's referencing the default classes and interfaces names.
> Has anybody else this problem ? There is a Bugzilla (317241) but it's
> open one year ago and stills has no answers.
> Thanks.
FUDForum. Page generated in 0.03949 seconds
