Home » Eclipse Projects » Eclipse 4 » Contribute from a fragment to a component in application
Contribute from a fragment to a component in application [message #685437] Fri, 17 June 2011 14:10 Go to next message
Christian Eugster is currently offline Christian EugsterFriend
I have two plugins: The first contains the Application.e4xmi, the second a Fragment.e4xmi. In Application.e4xmi I added a toolbar under Trimmed Window -> TrimBars->Window Trim with id "my.id". In Fragment.e4xmi I want to contribute a ToolItem to this toolbar. So in Fragment.e4xmi I added a String Model Fragment with id "my.id" and Feature children. To this I added a Handled Tool Item with Command "my.command" that was defined in another String Model Fragment with Element Id org.eclipse.e4.ide.application and featurename commands. I also added a handler under the same Element Id with reference to the same command.
When I start the application, the toolitem is not shown. The same is with menus I contribute from the fragment to the application. Do I missunderstand the tutorials or where did I do something wrong? And is there some deeper documentation around?
Thank you
Christian
Re: Contribute from a fragment to a component in application [message #686020 is a reply to message #685437] Tue, 21 June 2011 11:49 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
Hi Christian,
Could you post the fragment you're using to add your command/toolitem?
Thanx,
PW
Previous Topic:XWT ListViewer multi selection
Next Topic:Problem with command handlers
Current Time: Wed Feb 19 05:12:45 GMT 2020
Powered by FUDForum. Page generated in 0.07869 seconds
