td.valign=top everytime. Howto set to bottom? [message #684911] |
Thu, 16 June 2011 13:16 |
JW Messages: 9 Registered: June 2011 |
I format a text-element within a grid and I want to set a valign=bottom.
If I do that (via birt-styple xor css-style) than:
* looks the ReportDesigner very well (@see reportdesinger-screenshot)
* but if I preview my report into browser (firefox/chrome/safari) than all valign=top (@see preview-screenshot)
* and if I export my report to pdf than I got the same problem.
I want to configure this via css-file. What must I do? ( @see my.css what not worked at runtime)
* I added valign and vertical-align on many selectors.
I use birt-2.5.2(gallileo) on macosx (leopard) with java-1.6
Many THANKS for each reply.
[Updated on: Thu, 16 June 2011 13:27] Report message to a moderator
(no subject) [message #684956 is a reply to message #684911] |
Thu, 16 June 2011 13:51 |
This looks like a bug. Can you please log a bugzilla entry for this?
Jason
> Before, many THANKS for each reply.
(no subject) [message #684959 is a reply to message #684911] |
Jason
Re: (no subject) [message #684983 is a reply to message #684970] |
Thu, 16 June 2011 14:50 |
In 2.6.2 I got this to work in pdf just not html. It may be good to add
a sample report for the devs on that bugzilla entry.
Jason
On 6/16/2011 10:39 AM, JW wrote:
> Thanks for this quick reply.
> I've looked to birt-bug-repo and found this:
> bugs.eclipse.org/bugs/show_bug.cgi?id=344938
> * Its looks like same problem.
Re: (no subject) [message #685429 is a reply to message #685305] |
Fri, 17 June 2011 13:48 |
Thanks for doing this.
Jason
On 6/17/2011 4:36 AM, JW wrote:
> Jason Weathersby wrote on Thu, 16 June 2011 10:50
>> add a sample report for the devs on that bugzilla entry.
> Many thanks to Jason
> * I will upgrade my birt-runtime-dependency to 2.6.2 and test it.
> * And I will try to seperate the problem to a single report for
> bugzilla-ticket.
FUDForum. Page generated in 2.09619 seconds
