Why cant an extended type add an attribute [message #68612] |
Thu, 13 July 2006 08:54 |
Originally posted by: kannan.ekanath.gmail.com
I have an XSD model where I have extended SchoolBook to extend Book.
However after extending i am able to add elements to the school book but
i am not able to attributes to school book. The attached xsd has an
element an attribute for school book. Commenting out, the attribute
makes the schema valid.
I am curious to know why this restriction is present in the first place?
Kannan
*********************XSD*******************
<!-- edited with XMLSPY v5 rel. 4 U (http://www.xmlspy.com) by Kannan
Ekanath (Tavant) -->
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
ecore:documentRoot="library" ecore:package="tavant.platform.infra">
<xsd:complexType name="Book">
<xsd:sequence>
<xsd:element name="title" type="xsd:string"/>
<xsd:element name="pages" type="xsd:int"/>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Writer">
<xsd:sequence>
<xsd:element name="name" type="xsd:string"/>
<xsd:element name="books" type="xsd:anyURI" minOccurs="0"
maxOccurs="unbounded" ecore:opposite="author" ecore:reference="Book"/>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="library">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="writers" type="Writer" minOccurs="0"
maxOccurs="unbounded"/>
<xsd:element name="books" type="Book" minOccurs="0"
<xsd:element name="schoolbooks" type="SchoolBook" minOccurs="0"
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:complexType name="SchoolBook">
<xsd:complexContent>
<xsd:extension base="Book">
<xsd:sequence>
<xsd:element name="schoolName" type="xsd:string"/>
<xsd:attribute name="yyy" type="xsd:string"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:schema>
Re: Why cant an extended type add an attribute [message #68670 is a reply to message #68612] |
Thu, 13 July 2006 10:00 |
--------------090205000404020801000308
Kannan,
You're just using bad syntax. The attributes must come after the model
group.
<xsd:sequence>
</xsd:sequence>
* <xsd:attribute name="yyy" type="xsd:string"/> *
</xsd:extension>
</xsd:complexType>
Kannan Ekanath wrote:
> but i am not able to attributes to school book. The attached xsd has
> an element an attribute for school book. Commenting out, the attribute
> Kannan
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:complexType>
> <xsd:sequence>
> minOccurs="0" maxOccurs="unbounded"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:schema>
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Kannan,<br>
<br>
group.<br>
<blockquote> <xsd:complexType name="SchoolBook">
<br>
<br>
<br>
<xsd:sequence>
<br>
type="xsd:string"/>
<br>
</xsd:sequence>
<br>
<b> <xsd:attribute name="yyy" type="xsd:string"/>
</b><br>
</xsd:extension>
<br>
<br>
</xsd:complex Type> <br>
</blockquote>
<br>
<br>
<blockquote cite="mide951kp$kof$1@utils.eclipse.org" type="cite">Hi,
<br>
but i am not able to attributes to school book. The attached xsd has an
<br>
<br>
place?
<br>
<br>
<br>
Kannan
<br>
<br>
<br>
<br>
<!-- edited with XMLSPY v5 rel. 4 U (<a class="moz-txt-link-freetext" href="http://www.xmlspy.com">http://www.xmlspy.com</a>) by
Kannan Ekanath (Tavant) -->
<br>
<xsd:schema xmlns:xsd=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>
xmlns:ecore=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/emf/2002/Ecore"</a>
<br>
<xsd:complexT ype name="Book">
<br>
<xsd:sequence>
<br>
<br>
<br>
</xsd:sequence>
<br>
</xsd:complex Type>
<br>
<xsd:complexT ype name="Writer">
<br>
<xsd:sequence>
<br>
<br>
minOccurs="0" maxOccurs="unbounded" ecore:opposite="author"
<br>
</xsd:sequence>
<br>
</xsd:complex Type>
<br>
<br>
<xsd:complexType>
<br>
<xsd:sequence>
<br>
<br>
<br>
<br>
</xsd:sequence>
<br>
</xsd:complexType>
<br>
</xsd:element >
<br>
<xsd:complexT ype name="SchoolBook">
<br>
<br>
<br>
<xsd:sequence>
<br>
type="xsd:string"/>
<br>
<br>
</xsd:sequence>
<br>
</xsd:extension>
<br>
<br>
</xsd:complex Type>
<br>
</xsd:schema>
<br>
</blockquote>
<br>
</body>
</html>
--------------090205000404020801000308--
Re: Why cant an extended type add an attribute [message #68676 is a reply to message #68670] |
Fri, 14 July 2006 07:32 |
Ooops,
Misread the spec. You rock :)
Thanks !!!
Kannan
Ed Merks wrote:
> Kannan,
> group.
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
>> Hi,
>> Thanks,
>> Kannan
>> <?xml version="1.0" encoding="UTF-8"?>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:extension>
>> </xsd:complexType>
>> </xsd:schema>
Re: Why cant an extended type add an attribute [message #68686 is a reply to message #68676] |
Fri, 14 July 2006 08:32 |
In the same lines, i have one more doubt, when the school book is
created, the base class schoolnames comes first before other elements,
can you show some snippet where i can declare first my elements and then
extend base class? (Basically the xml created that way will have the
elements of this type coming up first and then followed by the base type?
> Ooops,
> Thanks !!!
> Kannan
> Ed Merks wrote:
>> Kannan,
>> model group.
>> <xsd:sequence>
>> type="xsd:string"/>
>> </xsd:sequence>
>> </xsd:extension>
>> </xsd:complexType>
>>> Hi,
>>> attribute makes the schema valid.
>>> Thanks,
>>> Kannan
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:extension>
>>> </xsd:complexType>
>>> </xsd:schema>
Re: Why cant an extended type add an attribute [message #68702 is a reply to message #68686] |
Fri, 14 July 2006 10:48 |
Kannan,
This isn't possible using a base type since the specification defines
the content type of an extension to consist of a particle that's a
sequence whose first particle is the base type's content type and whose
second particle is the derived type's locally defined content type.
> then extend base class? (Basically the xml created that way will have
> the elements of this type coming up first and then followed by the
> base type?
>> Ooops,
>> Thanks !!!
>> Kannan
>> Ed Merks wrote:
>>> Kannan,
>>> model group.
>>> <xsd:sequence>
>>> type="xsd:string"/>
>>> </xsd:sequence>
>>> </xsd:extension>
>>> </xsd:complexType>
>>>> Hi,
>>>> Book. However after extending i am able to add elements to the
>>>> school book but i am not able to attributes to school book. The
>>>> attached xsd has an element an attribute for school book.
>>>> Commenting out, the attribute makes the schema valid.
>>>> place?
>>>> Thanks,
>>>> Kannan
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:element>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:extension>
>>>> </xsd:complexType>
>>>> </xsd:schema>
Re: Why cant an extended type add an attribute [message #598359 is a reply to message #68612] |
Ed Merks Messages: 33140 Registered: July 2009 |
Kannan,
group.
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
> Kannan
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:schema>
<html>
<head>
<title></title>
</head>
Kannan,<br>
<br>
group.<br>
<br>
<br>
<br>
<xsd:sequence>
<br>
type="xsd:string"/>
<br>
</xsd:sequence>
<br>
</b><br>
</xsd:extension>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
place?
<br>
<br>
<br>
Kannan
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<xsd:sequence>
<br>
<br>
<br>
</xsd:sequence>
<br>
</xsd:complex Type>
<br>
<br>
<xsd:sequence>
<br>
<br>
<br>
</xsd:sequence>
<br>
</xsd:complex Type>
<br>
<br>
<xsd:complexType>
<br>
<xsd:sequence>
<br>
<br>
<br>
<br>
</xsd:sequence>
<br>
</xsd:complexType>
<br>
</xsd:element >
<br>
<br>
<br>
<br>
<xsd:sequence>
<br>
type="xsd:string"/>
<br>
<br>
</xsd:sequence>
<br>
</xsd:extension>
<br>
<br>
</xsd:complex Type>
<br>
</xsd:schema>
<br>
</blockquote>
<br>
</body>
</html>
Ed Merks
Re: Why cant an extended type add an attribute [message #598365 is a reply to message #68670] |
Ooops,
Thanks !!!
Kannan
Ed Merks wrote:
> Kannan,
> group.
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
>> Hi,
>> Thanks,
>> Kannan
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:extension>
>> </xsd:complexType>
>> </xsd:schema>
Re: Why cant an extended type add an attribute [message #598374 is a reply to message #68676] |
> Ooops,
> Thanks !!!
> Kannan
> Ed Merks wrote:
>> Kannan,
>> model group.
>> <xsd:sequence>
>> type="xsd:string"/>
>> </xsd:sequence>
>> </xsd:extension>
>> </xsd:complexType>
>>> Hi,
>>> Thanks,
>>> Kannan
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:extension>
>>> </xsd:complexType>
>>> </xsd:schema>
Re: Why cant an extended type add an attribute [message #598379 is a reply to message #68686] |
Kannan,
> base type?
>> Ooops,
>> Thanks !!!
>> Kannan
>> Ed Merks wrote:
>>> Kannan,
>>> model group.
>>> <xsd:sequence>
>>> type="xsd:string"/>
>>> </xsd:sequence>
>>> </xsd:extension>
>>> </xsd:complexType>
>>>> Hi,
>>>> place?
>>>> Thanks,
>>>> Kannan
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:element>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:extension>
>>>> </xsd:complexType>
>>>> </xsd:schema>
Ed Merks
FUDForum. Page generated in 0.04367 seconds
