Home » Archived » M2M (model-to-model transformation) » [ATL] Problem occurs when I launch an execution.
[ATL] Problem occurs when I launch an execution. [message #68579] Mon, 10 December 2007 19:13 Go to next message
Mikai Yang is currently offline Mikai YangFriend
Hi there:
I am a novice in using ATL. I just finished an example and want to run it
with a configuration. But a problem with the following exception occurred:
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:368)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
at
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
Help me, please.
Thanks.
Michael
Re: [ATL] Problem occurs when I launch an execution. [message #68701 is a reply to message #68579] Tue, 11 December 2007 09:27 Go to previous messageGo to next message
William Piers is currently offline William PiersFriend
--------------040803000809060607090306
Michael a
Re: [ATL] Problem occurs when I launch an execution. [message #68782 is a reply to message #68701] Tue, 11 December 2007 14:33 Go to previous message
Thanks, William. However, I have double checked the launch configuration and
did not find anything wrong. Moreover, I just copy the the source code from
an example in the ATL zoo and run it, the same problem is still there. Do
you have any idea?
Thanks.
Michael.
"William Piers" <william.piers@obeo.fr> wrote in message
news:fjll70$i9l$1@build.eclipse.org...
> Hello,
> Michael a
Previous Topic:what QVT for Eclipse has done to me (and questions for Quentin Glineur)
Next Topic:[ATL] How can generate the xmi model editor from a metamodel?
Current Time: Thu Oct 06 01:15:48 GMT 2022
Powered by FUDForum. Page generated in 0.01949 seconds
