Home » Modeling » EMF » Ant Problem(XSD2Java generates faulty Java Code)
Ant Problem [message #684334] Wed, 15 June 2011 12:39 Go to next message
Kai B. Heinz is currently offline Kai B. HeinzFriend
Hi there,
As I described here: http://www.eclipse.org/forums/index.php/mv/msg/210348/675052/#msg_675052 The XSD2Java Ant Task is a bit buggy. During my try to get a workaround by myself I found out that also wrong code is generated. Using the genmodel manually will result in:
public FeatureMap getAny() {
    return (FeatureMap)getMixed().<FeatureMap.Entry>list(MyPackage.eINSTANCE.getData_Any());
whereas XSD2Java generates:
    return (FeatureMap)getMixed().list(MyPackage.eINSTANCE.getData_Any());
with the result that Eclipse says: "Cannnot cast from EList<Object> to FeatureMap". In my whole model this happens just once, but it seems, that XSD2Java is not as reliable as the EMF UI. Not very useful for a nightly build Sad I hope development of the ANT Tasks will go on as they can be very useful!
regards
Kai
Re: Ant Problem [message #687206 is a reply to message #684334] Wed, 15 June 2011 13:32 Go to previous message
Kai,
Is your genmodel's compliance level set to 5.0? The difference you show
depends (getting the first result) on this being true:
<%final boolean isJDK50 = genModel.getComplianceLevel().getValue() >=
GenJDKLevel.JDK50;%>
Hopefully you're not generating a new *.genmodel each time but rather
reusing the same one you use in the IDE.
Kai B. Heinz wrote:
> Hi there,
> return
> nightly build :( I hope development of the ANT Tasks will go on as
> regards
> Kai
Ed Merks
Previous Topic:(no subject)
Next Topic:(no subject)
Current Time: Tue Apr 16 06:28:48 GMT 2024
Powered by FUDForum. Page generated in 0.26559 seconds
