Would you like to model both the domain layer and UML Objects at the same time ? [message #684298] |
Wed, 15 June 2011 11:35 |
Vlad Varnica Messages: 546 Registered: July 2009 Location: Milton Keynes - UK |
Object approach with UML is different from the domain layer modeling (e.g. database)
Having said that what do you think if you could create database stereotypes in your class diagram and immediately get ORM annotations in your java code ?
The concept is to use a database profile which allow you to add ORM stereotypes (e.g. Hibernate, EJB3) on classes, attributes and methods. When you add a stereotype then the ORM annotation is immediately created in your java code. Without much effort, you can get Hibernate to generate your database schema automatically, dispensing entirely with SQL scripts.
It is also a big time saver to think at object level. Annotations are a great way to manage your database persistence. With annotations, you don't need to bother with XML mapping files. You can also leverage the sensible default behavior to drastically reduce the amount of code you need to maintain.
Do you think that domain layer should be model at the same time as UML objects ?
[Updated on: Wed, 15 June 2011 11:36] Report message to a moderator
(no subject) [message #684352 is a reply to message #684298] |
Wed, 15 June 2011 13:08 |
Ed Merks Messages: 33137 Registered: July 2009 |
Vlad,
The subject line is a bit incoherent...
You mean an object-oriented approach, i.e., using inheritance?
I've never heard the "domain layer" modeling term. Databases use a
relational approach rather than an object oriented approach. Maybe
that's what you're getting at...
> in your java code ?
That's pretty much analogous to JPA in Java and Teneo's approach for ORM
mapping for Ecore...
> with SQL scripts.
Lots of people like this approach.
Using XML to describe ORM is just one approach. One might imagine a DSL
and of course annotations or stereotypes are really much like a DSL.
Yes, that's why many people like this approach.
> objects ?
I'd certain not call a relational representation "the domain layer" but
that's just terminology. One of the difficulties of ORM is how to map
an inheritance hierarchy onto tables. Of course if you avoid
inheritance, that particular problem goes away. Maybe that's why you've
been advocating inheritance avoidance...
Ed Merks
Re: (no subject) [message #684360 is a reply to message #684352] |
Wed, 15 June 2011 13:34 |
Ed,
I get your point which is to say that Teneo with EMF is the same as Java with annotations.
Hibernate/EJB3 are a standard as well as UML.
Teneo and EMF have already failed. Having said that what next ....
[Updated on: Wed, 15 June 2011 13:34] Report message to a moderator
Re: (no subject) [message #684388 is a reply to message #684360] |
Wed, 15 June 2011 14:04 |
Vlad,
Of course I don't agree that Teneo has failed, but that's just you being
provocative.
In terms of what next, people will use what they find is valuable.
Because many people find this approach of annotating/stereotyping their
primary object-oriented representation with ORM mapping information to
be extremely useful it's an approach we're bound to see continue well
into the future. Of course not everyone is looking to stuff their data
into a database, so not everyone will care about this topic...
Vlad Varnica wrote:
> Ed,
> Teneo and EMF have already failed having said that what next ....
Ed Merks
FUDForum. Page generated in 0.03503 seconds
