Home » Modeling » OCL » Direct access to pre/post conditions of an context operation
Direct access to pre/post conditions of an context operation [message #68466] |
Thu, 05 March 2009 16:27 |
Timothy Marc Messages: 547 Registered: July 2009 |
Hey all again,
is there the possibility to navigate directly to a pre/post condition of
an operation, defined in a ocl document. i want to handle only some
preconditions, which have specific name.
I was wondering, that there is no getPreconditions() metod for
operations. i know, inside the uml spec, every operation can define a
number of pre/postconditions directly. but how can i access the ast of
each precondition, if i haven't the possibility to access them?
and is there the possibility to serialize the generated ast (the ocl
metamodel instrance) for visualizing it with the emf editor?
thanks again. i hope after getting access to the pre/ostconditions, i
won't have so much questions any more. imho, in contrast to the uml
spec, the ocl spec is much more confusing and harder to understand.
Timothy
Re: Direct access to pre/post conditions of an context operation [message #68507 is a reply to message #68466] |
Fri, 06 March 2009 14:01 |
Originally posted by: cdamus.zeligsoft.com
Hi, Timothy,
See some replies in-line, below.
HTH,
Christian
Timothy Marc wrote:
> Hey all again,
If you assign your constraints names (between the "pre" or "post"
keyword and the colon), then you will be able to find them again, after
parsing.
You can determine that a constraint is a pre- or post-condition of an
operation by checking that UMLReflection::getConstrainedElements(...)
includes your operation. Get the name of the constraint using
UMLReflection::getName(...).
The OCL façade object through which you parsed the OCL constraints keeps
track of them. You can find them all using OCL::getConstraints().
These are the ASTs. Then, it's a matter of using the UMLReflection API
as I mentioned above to find the right constraint. There is potential,
here, for handy additions to the OCLUtil class ...
Yes. You can serialize the environment, which includes all of the
constraints that you parsed, additional operation/attribute definitions
("helpers"), demand-created collection types, etc. Just get the
Environment's resource, set a useful URI, and save it:
Environment<...> myEnv = /* ... */;
Resource res = myEnv.getTypeResolver().getResource();
// set res's URI and save it
Well, the newsgroup is always here to answer. :-)
> Timothy
Re: Direct access to pre/post conditions of an context operation [message #68561 is a reply to message #68507] |
Fri, 06 March 2009 20:36 |
Christian,
so, it is me again for the (hopefully) last question today. I tried to
serialize the parsed ast, but i got a ClassNotFoundException, when i
open the xmi with the sample reflective edtitor.
The Class "ExpressionInOcl" could not be found. I think, the connection
to the ocl.uml metamodel is lost??? Is it so?
And by the way, how can the OCL AST View be used? I don't know how to
pass an ast to it, since it seems that there is no functionality
implemented.
Thx
Timothy
Christian W. Damus schrieb:
> Hi, Timothy,
> HTH,
> Christian
> Timothy Marc wrote:
>> Hey all again,
>> of an operation, defined in a ocl document. i want to handle only some
> parsing.
> track of them. You can find them all using OCL::getConstraints(). These
> are the ASTs. Then, it's a matter of using the UMLReflection API as I
> mentioned above to find the right constraint. There is potential, here,
>> Timothy
Re: Direct access to pre/post conditions of an context operation [message #68615 is a reply to message #68561] |
Wed, 11 March 2009 13:28 |
Hi, Timothy,
Is your code running in an Eclipse instance? If so, you should have no
trouble find this class because the OCL-UML metamodel is statically
registered. Otherwise, you would have to take care of the package
registrations, yourself. The org.eclipse.ocl.standalone.tests project
provides a complete example of how to do that: it runs the OCL JUnit
tests in an Eclipse-free context.
I don't know what condition the OCL AST View is in. It hasn't been
updated in years, as far as I know, so it may be out of touch with the
OCL API. Best to ask its authors about that.
HTH,
Christian
Timothy Marc wrote:
> Christian,
> implemented.
> Thx
> Timothy
>> Hi, Timothy,
>> HTH,
>> Christian
>> Timothy Marc wrote:
>>> Hey all again,
>>> some preconditions, which have specific name.
>> after parsing.
>>> of each precondition, if i haven't the possibility to access them?
>> keeps track of them. You can find them all using
>> OCL::getConstraints(). These are the ASTs. Then, it's a matter of
>> using the UMLReflection API as I mentioned above to find the right
>> constraint. There is potential, here, for handy additions to the
>> OCLUtil class ...
>> definitions ("helpers"), demand-created collection types, etc. Just
>> get the Environment's resource, set a useful URI, and save it:
>>> Timothy
Current Time: Wed Apr 24 17:31:19 GMT 2024
Powered by FUDForum. Page generated in 0.03402 seconds
