Home » Modeling » Graphiti » Overriding the Add feature(Cannot get the add feature to work correctly)
Overriding the Add feature [message #683527] Mon, 13 June 2011 23:23 Go to next message
vrm  is currently offline vrm Friend
Member
Hello Folks,
I'm new to Graphiti and following the Online Tutorial to get my hands on with this tool.As described in the tutorial,i implemented the Add feature but when I test it , it doesnt seem to work.On debugging,I found that the canAdd() feature returned me a false as the targetConnection of the active context was null.I cant figure out what the problem is ? Any suggestions.
VM
Re: Overriding the Add feature [message #683694 is a reply to message #683527] Tue, 14 June 2011 08:55 Go to previous message
Michael Wenz is currently offline Michael WenzFriend
At a first glance I would suggest to check that the linking between the
shapes for the EClasses and the actualm EClass objects are correctly set. To
say more I would need to debug that...
I would suggest to also compare the behavior to the one of the finished
tutorial example, maybe that helps to identify the bug.
Michael
"vrm" schrieb im Newsbeitrag news:it65l4$3nm$1@news.eclipse.org...
Hello Folks,
VM
Previous Topic:Double lined arrow
Next Topic:Collapse Feature Bug?
Current Time: Mon Jan 18 11:37:55 GMT 2021
Powered by FUDForum. Page generated in 0.01276 seconds
