Home » Modeling » GMF (Graphical Modeling Framework) » Hiding and unhiding elements / editparts
Hiding and unhiding elements / editparts [message #683431] Mon, 13 June 2011 17:48 Go to next message
Ivar Refsdal is currently offline Ivar RefsdalFriend
I'm trying to hide (and unhide) some elements using the notation view in
GMF.
Hiding works fine. This is done through a parent element.
However, how can one go about to unhide these elements (through the same
parent element)?
I'm using the following code:
> public void hideSelfAndChildren(GraphicalEditPart part, TransactionalEditingDomain ted, CompoundCommand cc) {
> View v = ((GraphicalEditPart) part).getNotationView();
> Boolean newVal = v.isVisible() ? Boolean.FALSE : Boolean.TRUE;
> SetCommand cmd = new SetCommand(ted, v, NotationPackage.Literals.VIEW__VISIBLE, newVal);
> cc.append(cmd);
> System.err.println("changing visibility of " + part);
> for (GraphicalEditPart child : getChildren(part)) {
> hideSelfAndChildren(child, ted, cc);
> private List<GraphicalEditPart> getChildren(GraphicalEditPart part) {
> List<GraphicalEditPart> children = new LinkedList<GraphicalEditPart>();
> for (Object childConnection : part.getSourceConnections()) {
> System.err.println("found outgoing connection...");
> if (childConnection instanceof AbstractConnectionEditPart) {
> AbstractConnectionEditPart child = (AbstractConnectionEditPart)childConnection;
> EditPart target = child.getTarget();
> if (target instanceof GraphicalEditPart) {
> children.add((GraphicalEditPart) target);
> return children;
> public void run(IAction action) {
> if (selection==null) return;
> if (selection instanceof IStructuredSelection) {
> if (((IStructuredSelection) selection).getFirstElement() instanceof GraphicalEditPart) {
> GraphicalEditPart part = (GraphicalEditPart) ((IStructuredSelection) selection).getFirstElement();
> TransactionalEditingDomain ted = part.getEditingDomain();
> CompoundCommand cc = new CompoundCommand();
> System.err.println("");
> int cnt = 0;
> System.err.println("doing child " + child);
> cnt++;
> if (cnt==0) {
> System.err.println("trying to restore part.. ");
> part.refresh();
> // todo: how to unhide?
> } else {
> System.err.println("executing compoundcommand");
> ted.getCommandStack().execute(cc);
When trying to unhide elements, child.getTarget() simply returns null.
How does one restore that editPart? Any clues?
Thanks and all the best,
Ivar Refsdal
Re: Hiding and unhiding elements / editparts [message #683852 is a reply to message #683431] Tue, 14 June 2011 14:04 Go to previous message
Hi all,
I found a solution for this.
To retrieve the hidden views one can do something like this:
> private List<View> invisibleViews(GraphicalEditPart part) {
> List<View> result = new LinkedList<View>();
> ResourceSet resSet = part.getEditingDomain().getResourceSet();
> for (Resource res : resSet.getResources()) {
> if (res instanceof GMFResource) {
> Iterator<EObject> it = res.getAllContents();
> while (it.hasNext()) {
> EObject obj = it.next();
> if (obj instanceof View) {
> View v = (View) obj;
> if (v.isVisible()==false) {
> result.add(v);
> return result;
Then the View will have a .getElement() which returns your domain
object. So, one can use something like this (this is the easy part..):
> List<EObject> children = semanticChildren(part, new LinkedList<EObject>());
> System.err.println("and the children are " + children);
> for (View view : invisibleViews(part)) {
> if (children.contains(view.getElement())) {
> SetCommand cmd = new SetCommand(ted, view, NotationPackage.Literals.VIEW__VISIBLE, Boolean.TRUE);
> cc.append(cmd);
> part.refresh();
semanticChildren of course needs to return the semantic children (i.e.
domain objects) of the part that was clicked.
The hiddenness of the objects are persisted across sessions and so on. I
did not discover any problems with this, but then again of course there
may be..
Is this the "right" way to do it, or is there a better way? Comments
would be appreciated.
Ivar
Ivar Refsdal wrote, on 06/13/2011 07:48 PM:
> GMF.
> parent element)?
>> cc.append(cmd);
>> return children;
>> int cnt = 0;
>> cnt++;
>> if (cnt==0) {
>> part.refresh();
>> } else {
> Ivar Refsdal
Re: Hiding and unhiding elements / editparts [message #683853 is a reply to message #683431] Tue, 14 June 2011 14:04 Go to previous message
Hi all,
> result.add(v);
> return result;
> cc.append(cmd);
> part.refresh();
may be..
Ivar
> GMF.
> parent element)?
>> cc.append(cmd);
>> return children;
>> int cnt = 0;
>> cnt++;
>> if (cnt==0) {
>> part.refresh();
>> } else {
> Ivar Refsdal
Previous Topic:why save failed
Next Topic:Customize command "Initialize XXX model diagram" => Don't arrange everything horizontal
Current Time: Tue Dec 03 18:04:34 GMT 2024
Powered by FUDForum. Page generated in 0.03463 seconds
