[TEXO] No Texo in Project Properties [message #683310] |
Mon, 13 June 2011 13:44 |
gdelprete Messages: 10 Registered: June 2011 |
i'm trying overriding templates in Texo code generation.
Unfortunately, I cannot find the "Texo" tab in the project's properties dialog which I need to set the templates folder path.
Alternatively, where can I set the templates folder path without using the GUI?
Please note that even if I name the folder "templates" (the default value as per the screenshot on Texo's homepage), may templates are not considered.
Using TEXO stable release (i.e. not nightly releases), under Eclipse Helios SR 2.
Can someone help me?
Gabriele
[Updated on: Mon, 13 June 2011 13:45] Report message to a moderator
Re: [TEXO] [message #683329 is a reply to message #683310] |
Mon, 13 June 2011 14:09 |
You have to enable the texo nature on the project. Right click on the project and then in the Configure menu choose
add/remove texo nature. Then in the project properties a Texo section appears.
gr. Martin
On 06/13/2011 03:44 PM, forums-noreply@eclipse.org wrote:
> Hello,
> path.
> Regards,
> Gabriele
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.01414 seconds
