Home » Archived » M2M (model-to-model transformation) » [ATL] : Bug report ? UML 2 Driver and Primitive types from pathmap
[ATL] : Bug report ? UML 2 Driver and Primitive types from pathmap [message #68332] Fri, 07 December 2007 08:32 Go to next message
Originally posted by: tristan.faure.c-s.fr
Hi i want to notify a very strange behaviour ...
I've made a simple transformation that copies UML property to UML Property
(metamodel UML2.1.0)
The properties in my input model have a type, an UML primitive type :
Integer, String ...
With EMF Driver : OK, the types are copied with the properies
With UML2 Driver : KO, Properties are copied but no types : fields are
empty.
Do you have a solution ? any idea ? or is it a bug .... ?
Re: [ATL] : Bug report ? UML 2 Driver and Primitive types from pathmap [message #68343 is a reply to message #68332] Fri, 07 December 2007 09:50 Go to previous messageGo to next message
William Piers is currently offline William PiersFriend
--------------030500080001020903090206
Tristan FAURE a
Re: [ATL] : Bug report ? UML 2 Driver and Primitive types from pathmap [message #68352 is a reply to message #68343] Fri, 07 December 2007 12:35 Go to previous message
Thank you for your answer but i've already checked this solution and i
have the same error
in fact i had this error using superimposition with module UML2Copy (taken
in ATL wiki)
for the bug i will report it when i'll receive my account :(
Previous Topic:[ATL] Launch programmatically + Transformation from UML2 with Profile
Next Topic:ATL transformation from UML2 to OWL
Current Time: Sun Oct 02 02:41:25 GMT 2022
Powered by FUDForum. Page generated in 0.02725 seconds
