Boolean operations and OCLUndefined [message #68330] |
Tue, 03 March 2009 07:54 |
--------------080302050500090201010307
Hi Christian,
I stumbled upon this while trying to debug an OCL expression and was
wondering ... Nowhere in the OCL specification is it defined the result
of a boolean expression if one of the sides are "OCLUndefined", or at
least I didn't find a reference.
When evaluating "OCLUndefined and b", whatever the value of b, the
result will be false. Likewise, evaluating "OCLUndefined or b" will
return the value of b (see case PredefinedType.OR: and case
PredefinedType.AND: on lines 915 and 938 of the EvaluationVisitorImpl).
I would have expected results as :
OCLUndefined and true => OCLUndefined
OCLUndefined and false => false
OCLUndefined or true => true
OCLUndefined or false => OCLUndefined
But seeing how my boolean expression *should* fail and does not (my case
was the "OCLUndefined and true" is quite unsettling. Was this
implementation choice due to a gap in the specification or was that an
overlook?
Laurent Goubet
Obeo
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr/">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------080302050500090201010307--
Re: Boolean operations and OCLUndefined [message #68351 is a reply to message #68330] |
Tue, 03 March 2009 19:08 |
Originally posted by: cdamus.zeligsoft.com
Hi, Laurent,
This looks like a bug to me. Any operation on 'null' (which I assume is
what you mean by "OCLUndefined") should result in 'invalid' (which MDT
OCL erroneously refers to as OclInvalid).
According to the OCL spec, the result of any operation invocation or
property access on the null value is invalid, unless it is an operation
explicitly defined for OclVoid. The only such operations are =, <>,
oclIsUndefined(), and oclIsInvalid().
At least, that is my understanding of the matter ...
Christian
laurent Goubet wrote:
> Hi Christian,
> overlook?
> Laurent Goubet
> Obeo
Re: Boolean operations and OCLUndefined [message #68412 is a reply to message #68351] |
Thu, 05 March 2009 09:49 |
--------------010807010600090507000105
Hi Christian,
Sorry about that, the behavior of boolean operations is indeed defined
in the OCL specifications at "A.2.1.4 SEMANTICS OF OPERATIONS" (page 188
of version 2.0 formal/06-05-01).
That looked like a bug to me too yes, if I can understand that "null and
false" returns false, "null and true" should fail in my understanding.
Though it seems the OMG people don't see this like that. I guess I'll
have to cope with this behavior.
Laurent Goubet
Obeo
Christian W. Damus a
Re: Boolean operations and OCLUndefined [message #68423 is a reply to message #68412] |
Thu, 05 March 2009 09:52 |
--------------030900090203090409080101
.... and it seems I have trouble reading. I'll have to try and get a some
rest :p. The OCL specification goes in the direction of my first post :
I'll raise a bug for this
Laurent Goubet
Obeo
laurent Goubet a
Re: Boolean operations and OCLUndefined [message #68497 is a reply to message #68457] |
Fri, 06 March 2009 13:47 |
Thanks, Laurent! And for the patch, too, of course.
cW
> just raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=267223 with a
> patch adressing this issue (no unit test to ensure the behavior though).
> laurent Goubet
> Obeo
>> some rest :p. The OCL specification goes in the direction of my first
>> post :
>> Regards,
>> Laurent Goubet
>> Obeo
-----8<-----
FUDForum. Page generated in 0.03513 seconds
