Home » Language IDEs » ServerTools (WTP) » Apache 7.0 Installation with Eclipse(Appache Server port is used by another service !!!!!)
Apache 7.0 Installation with Eclipse [message #682699] Sat, 11 June 2011 21:36 Go to next message
Khajan Yadav is currently offline Khajan YadavFriend
I m using Eclipse 3.3 and have install tomcat apache server 7.0 for my processing but whenever i try to run a program on server it gives me an error stating that the port specified are used by some other application. I m using Mac Os x 10.6 snow leapard. Kindly help me to resolve this issue.
I m getting either the above message or sometimes a msgbox pops up stating that the requested page is not found
[Updated on: Sat, 11 June 2011 21:38]
Report message to a moderator
Re: Apache 7.0 Installation with Eclipse [message #682713 is a reply to message #682699] Sat, 11 June 2011 22:12 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 2011.06.11 15:36, Khajan Yadav wrote:
> Hi I m using Eclipse 3.3 and have install tomcat apache server 7.0 for
> resolve this issue.
In the Servers tab/view usually at the bottom of the Eclipse workbench,
double-click Tomcat v7.0 at localhost. This will bring up an editor (in
your Editor view) where you can change the port as used by Eclipse/Tomcat.
That should solve it.
Re: Apache 7.0 Installation with Eclipse [message #682815 is a reply to message #682713] Sun, 12 June 2011 05:53 Go to previous messageGo to next message
Hi Russel.... i tried it that way but the problem still persists.....Do u hav any other suggestion????
Re: Apache 7.0 Installation with Eclipse [message #683303 is a reply to message #682713] Mon, 13 June 2011 13:24 Go to previous message
Larry Isaacs is currently offline Larry IsaacsFriend
>> resolve this issue.
Also, for more info about what is going on, see the WTP Tomcat FAQ[1].
Larry
[1] http://wiki.eclipse.org/WTP_Tomcat_FAQ
Previous Topic:Weblogic Server Plugin in Eclipse Helios Service Release 2
Next Topic:Publishing unpacks EAR dependency JARs *every time*
Current Time: Sat Feb 27 19:46:42 GMT 2021
Powered by FUDForum. Page generated in 0.02428 seconds
