Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Jet template to acceleo converter
[Acceleo] Jet template to acceleo converter [message #681989] Fri, 10 June 2011 07:41 Go to next message
Maxime Jeanmart is currently offline Maxime JeanmartFriend
Member
Hi all,
Is there any exiting tool that help converting a jet template into an acceleo template?
Max
Re: [Acceleo] Jet template to acceleo converter [message #682024 is a reply to message #681989] Fri, 10 June 2011 08:59 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
Since JET and Acceleo are template based generator, it is pretty straightforward to go from one to the other. You can quickly convert a template with a simple "search and replace". We also have a automatic system to realize the conversion of JET templates to Acceleo templates easily but it is not publicly available right now but it could be easily.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: [Acceleo] Jet template to acceleo converter [message #682043 is a reply to message #682024] Fri, 10 June 2011 09:25 Go to previous messageGo to next message
Hi Stephane
I would like to add direct generation of Java from OCL in an Indigo+0.5
release, so that OCL can be used by OCL tooling with much reduced
efficiency concerns. This requires genmodel integration, which probably
means JET template enhancement.
It would be really good if the EMF, UML2 templates could be officially
migrated to Acceleo so that those of us who regard JET as a scary
dinosaur can use a friendly monster instead.
Ed Willink
On 10/06/2011 09:59, Stephane Begaudeau wrote:
> Regards,
> Twitter: http://twitter.com/#!/sbegaudeau
Re: [Acceleo] Jet template to acceleo converter [message #682116 is a reply to message #682043] Fri, 10 June 2011 12:52 Go to previous messageGo to next message
Hi Ed,
It would be really good if the EMF, UML2 templates could be officially migrated to Acceleo so that those of us who regard JET as a scary dinosaur can use a friendly monster instead.
Well, EEF 1.0 is providing an Acceleo based EMF generation for EMF Edit and EMF Editor with its Indigo release. Model and Tests will come later but the work is already in progress.
Re: [Acceleo] Jet template to acceleo converter [message #694897 is a reply to message #681989] Sun, 10 July 2011 06:37 Go to previous message
David Sauter is currently offline David SauterFriend
I don't suppose that your converter can handle JET2... and if so how nicely do I need to say please to get my hands on it for an afternoon?
I have a fairly large (and fairly time sensitive) project using JET2 that I ran into some roadblocks and want to convert it to Acceleo. It's proving problematic however as there's no simple find/replace for the control nodes from JET2 that I've seen.
David Sauter
Previous Topic:let expression for a set in XPand and Xtend
Next Topic:Import different Toolchains in Eclipse
Current Time: Mon Jun 05 10:40:44 GMT 2023
Powered by FUDForum. Page generated in 0.01469 seconds
