Re: Export to Multiple Platforms [message #682159 is a reply to message #682122] |
Fri, 10 June 2011 14:26 |
Alfred Sterphone Messages: 5 Registered: June 2011 |
This is excellent. Thanks for the tip. I've added the Delta Pack as a Target Platform within Eclipse RCP, but I cannot get my code to compile once I've done this. I've tried tweaking the plugin settings, but to no avail. I can't even find a tutorial online. Maybe I've been searching for the wrong things? Any additional help would be appreciated. In the meantime, I'm going to continue to mess around to try and get it to work. If I do, I will post back here. Thanks!
Edit: I've found this (www.vogella.de/articles/EclipsePDEBuild/article.html#deltapack), and am about to try it.
Edit2: While the tutorial was very helpful, I am failing at the last step. Google is not helpful with my error...
Unable to find plug-in: com.ibm.icu_0.0.0. Please check the error log for more details.
There is no error log, and I am completely stuck. Any help appreciated...
Edit3: Fixed that error by properly adding the feature. I had confused "feature" with "product" clearly, they are not the same. Presented with new error. Plugin for org.eclipse.equinox.launcher.<version> not found. Resolved below.
[Updated on: Fri, 10 June 2011 18:11] Report message to a moderator
FUDForum. Page generated in 0.02839 seconds
