Home » Eclipse Projects » Plugin Development Environment (PDE) » Is it possible to substitute a bundle's class with another one coming from a fragment?
Is it possible to substitute a bundle's class with another one coming from a fragment? [message #68094] Tue, 14 July 2009 12:06 Go to next message
Victor Roldan Betancort is currently offline Victor Roldan BetancortFriend
Hi dear community,
I'm trying to substitute a class from a bundle I'm not allowed to
modify. I've tried using fragments, but with no result.
What I did was to create in the fragment a package with the same name as
the host bundle's target package where the class is contained. That
didn't work.
I've read also about the "import your exported" best practice. Not sure
If I understood it correctly: the OSGi runtime would import those
packages from other bundles, even when it's present in the declaring
bundle? Assuming this is right, I modified the fragment's MANIFEST to
include these "import your exported" packages. It didn't work either :(
Any tips on how to solve this?
Víctor.
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #68110 is a reply to message #68094] Tue, 14 July 2009 18:57 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
Víctor Roldán Betancort wrote:
> Hi dear community,
> didn't work.
Try creating a Feature Patch (available in the New Project wizard); my
understanding is that a feature patch can be used to "patch" or replace
some part of an existing feature.
Hope this helps,
Eric
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #68139 is a reply to message #68110] Wed, 15 July 2009 09:58 Go to previous messageGo to next message
Hi Eric,
thanks for your tip. Comments below:
>> Hi dear community,
>> as the host bundle's target package where the class is contained. That
>> didn't work.
>> sure If I understood it correctly: the OSGi runtime would import those
> Hope this helps,
> Eric
I'm not sure this suits my needs. First, would need to create a feature
for the bundle to patch, since there isn't any defined for it. Second,
the feature patch look more like a forking a bundle, I would have to
include in the feature patch the modified version of the bundle to
patch. In the end I'll be maintaining a modified version of the whole
bundle. I would like to "complement" that bundle instead.
My situation is the following. The bundle is created by some colleague.
I'm can't modify his work (lets say, for bureaucratic reasons). That
bundle is shared among my colleagues in their workspaces. I can't ask
them to use my forked version. Instead, when they fetch the bundles that
conform my part of the work, they'd be also obtain a patch for another
bundle (this latter now being under my control).
Once the bureaucratic reasons expire, I'll be able to open a enhancement
request over that host bundle, and then discard the fragment patch or
whatever it shall be.
Is there any known hack to substitute code?
Maybe I could take a look also at byte-code manipulation frameworks....
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #68150 is a reply to message #68139] Wed, 15 July 2009 12:41 Go to previous messageGo to next message
Originally posted by: ekkehard.gentz-software.de
a very good description how to use Patch Fragments you'll find here:
http://konigsberg.blogspot.com/2009/06/patch-fragments-redux .html
ekke
Víctor Roldán Betancort schrieb:
> Hi Eric,
>>> Hi dear community,
>>> That didn't work.
>>> those packages from other bundles, even when it's present in the
>>> declaring bundle? Assuming this is right, I modified the fragment's
>>> MANIFEST to include these "import your exported" packages. It didn't
>>> work either :(
>> replace some part of an existing feature.
>> Hope this helps,
>> Eric
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #68162 is a reply to message #68150] Wed, 15 July 2009 15:31 Go to previous messageGo to next message
Ekke,
really interesting post. I tried and it worked, indeed.
However, I still have the same problem: It requires to maintain a
modified version of the host bundle.
After investigating a bit, I considered creating my own ClassLoadingHook
extension, and substituting the byte code of the target class with the
one from the corrected one (I'll be probably using ASM or something like
that).
Víctor.
> ekke
>> Hi Eric,
>>>> Hi dear community,
>>>> name as the host bundle's target package where the class is
>>>> contained. That didn't work.
>>>> work either :(
>>> my understanding is that a feature patch can be used to "patch" or
>>> Hope this helps,
>>> Eric
>> feature for the bundle to patch, since there isn't any defined for it.
>> Second, the feature patch look more like a forking a bundle, I would
>> have to include in the feature patch the modified version of the
>> bundle to patch. In the end I'll be maintaining a modified version of
>> the whole bundle. I would like to "complement" that bundle instead.
>> colleague. I'm can't modify his work (lets say, for bureaucratic
>> reasons). That bundle is shared among my colleagues in their
>> workspaces. I can't ask them to use my forked version. Instead, when
>> they fetch the bundles that conform my part of the work, they'd be
>> also obtain a patch for another bundle (this latter now being under my
>> control).
>> enhancement request over that host bundle, and then discard the
>> fragment patch or whatever it shall be.
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #68175 is a reply to message #68150] Wed, 15 July 2009 18:22 Go to previous message
Finally managed to solve doing the following:
1. created a ClassLoadingHook
2. It intercepts the loading of the classes to be patched
3. Using ASM, it generates the byte code for the modified version and
its returned when calling:
org.eclipse.osgi.baseadaptor.hooks.ClassLoadingHook.processC lass(String,
byte[], ClasspathEntry, BundleEntry, ClasspathManager)
However, now my problem is the ASM jar file, which I included in the
fragment's classpath (Bundle-ClassPath) is not properly in runtime, and
when loading classes from it I get a ClassNotFoundException. I fixed it
by including ASM source code in the fragment, but it is not a solution I
really like.
Am I missing anything here? What should be done to properly make a jar
library be included in the host's classpath?
Víctor.
> ekke
>> Hi Eric,
>>>> Hi dear community,
>>>> work either :(
>>> Hope this helps,
>>> Eric
>> control).
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #599352 is a reply to message #68094] Tue, 14 July 2009 18:57 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
> Hi dear community,
> didn't work.
Hope this helps,
Eric
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #599369 is a reply to message #68110] Wed, 15 July 2009 09:58 Go to previous message
Hi Eric,
>> Hi dear community,
>> didn't work.
> Hope this helps,
> Eric
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #599380 is a reply to message #68139] Wed, 15 July 2009 12:41 Go to previous message
ekke
> Hi Eric,
>>> Hi dear community,
>>> That didn't work.
>>> work either :(
>> Hope this helps,
>> Eric
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #599387 is a reply to message #68150] Wed, 15 July 2009 15:31 Go to previous message
Ekke,
that).
Víctor.
> ekke
>> Hi Eric,
>>>> Hi dear community,
>>>> work either :(
>>> Hope this helps,
>>> Eric
>> control).
Re: Is it possible to substitute a bundle's class with another one coming from a fragment? [message #599395 is a reply to message #68150] Wed, 15 July 2009 18:22 Go to previous message
really like.
Víctor.
> ekke
>> Hi Eric,
>>>> Hi dear community,
>>>> work either :(
>>> Hope this helps,
>>> Eric
>> control).
Previous Topic:diagnose plugin hang
Next Topic:Semantic highlighting
Current Time: Wed Jul 28 08:48:14 GMT 2021
Powered by FUDForum. Page generated in 0.02140 seconds
