Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Transactions] multiple editing domains for one resource set
[Transactions] multiple editing domains for one resource set [message #67705] |
Tue, 09 January 2007 12:19  |
Originally posted by: jacek.pospychala.gmail.com
Hi!
is it possible to have many editing domains for one resource set?
What i would like to do is to have separate editing domain for an
editor, for my analysis plug-ins and for something else.
Then editor could easily use undo/redo in it's editing domain, and other
plugins in the same way. But they'll be operating on a shared model.
thanks for any suggestions
Jacek Pospychala
Re: [Transactions] multiple editing domains for one resource set [message #67812 is a reply to message #67705] |
Thu, 11 January 2007 10:31   |
Ok, i have found many editing domains to work. however i am still
interested in relations between transactions from separate domains, that
use the same (and different) objects in one resource.
Jacek Pospychala napisał(a):
> Hi!
> Jacek Pospychala
Re: [Transactions] multiple editing domains for one resource set [message #67997 is a reply to message #67812] |
Thu, 11 January 2007 22:28   |
Hi, Jacek,
Are you sure that this works as you expect? Each of the editing domains
that you have associated with your resource set will be independently
recording *all* changes in that resource set.
If your different editors, in their different editing domains, don't always
undo all of their command stacks and redo them in sync, then the model
(i.e., contents of the resource set) will be out of sync with the command
stacks of your editing domains. Undo/redo of a command is only valid when
the resource set is in the state that it was in when that command was last
done/undone (respectively).
The relationship between editing domain and resource set is intended to be
1:1, especially in the case of the transactional editing domain.
Christian
>> Hi!
>> Jacek Pospychala
Re: [Transactions] multiple editing domains for one resource set [message #68039 is a reply to message #67997] |
Thu, 11 January 2007 22:57   |
Originally posted by: jacekp.siat.pl
You're right - i was tooo optimistic
I have only succeeded with creating many editing domains (for 1 ResSet)
and accessing objects through these domains. performing changes on more
than one of them resulted with "transaction is closed" or "needs write
permission".
I suppose, synchronising many domains would require much more
sophisticated transaction mechanisms, that the current ones. Anyway i
consider two other solutions now:
1. if an editing domain could be associated to only a resource or a part
of model and not whole resource set. that would be great, because most
of the time editors will be modifying distinct parts of model.
2. if i could make a copy of resource set, or a part of it, create a
temporary resource set, associate editing domain, and apply changes from
time to time by merging temporary resource set with the original one.
what do you think?
Jacek
Christian W. Damus napisał(a):
> Hi, Jacek,
> Cheers,
> Christian
>>> Hi!
>>> Jacek Pospychala
Re: [Transactions] multiple editing domains for one resource set [message #68057 is a reply to message #68039] |
Thu, 11 January 2007 23:39   |
Hi, Jacek,
Yes, every time that you wish to make a change to the model, you would have
to open a transaction in *every* editing domain.
The editing domain really is intended to manage an entire resource set. If
your different editors are editing independent resources, then you can
certainly keep these resources in different resource sets, each with its
own editing domain. However, merging changes between different copies of
the same resources is going to be problematic: first, you need some kind
of compare/merge facility and, second, any merge would have to be recorded
and placed on the Undo/Redo history of the editor doing the merge. I doubt
that you want your users to be able to undo these merges ;-)
Why do your editors need their own editing domains? I know of several
GMF-based applications that work very well with multiple editors editing
different resources in the same resource set and editing domain. If you
use the org.eclipse.emf.workspace plug-in to implement your Undo/Redo menus
using the Eclipse IOperationHistory API, then you will get independent
undo/redo actions in your different editors when the changes in an editor
do not affect the other editors' resources. Where a change does affect
multiple editors' resources, then all affected editors will have the same
action on their Undo menus.
Try installing the "EMFT Workspace Integration" editor example in your
workspace to see how this works in practice. You will find it in the
"New -> Project..." menu, in the Examples category.
HTH,
Christian
> permission".
> what do you think?
> Jacek
<snip>
Re: [Transactions] multiple editing domains for one resource set [message #68074 is a reply to message #68057] |
Fri, 12 January 2007 00:39  |
thanks! i'll look at emf.workspace tomorrow. i thought it only adapts
emf.transactions to eclipse operations framework, but now it looks more
like that what i want.
> Hi, Jacek,
> HTH,
> Christian
>> permission".
>> what do you think?
>> Jacek
> <snip>
Re: [Transactions] multiple editing domains for one resource set [message #601176 is a reply to message #67812] |
Hi, Jacek,
Christian
>> Hi!
>> Jacek Pospychala
Re: [Transactions] multiple editing domains for one resource set [message #601183 is a reply to message #67997] |
Jacek Pospychala Messages: 159 Registered: July 2009 |
permission".
what do you think?
Jacek
> Hi, Jacek,
> Cheers,
> Christian
>>> Hi!
>>> Jacek Pospychala
Re: [Transactions] multiple editing domains for one resource set [message #601192 is a reply to message #68039] |
Hi, Jacek,
HTH,
Christian
> permission".
> what do you think?
> Jacek
<snip>
Re: [Transactions] multiple editing domains for one resource set [message #601202 is a reply to message #68057] |
> Hi, Jacek,
> HTH,
> Christian
>> permission".
>> what do you think?
>> Jacek
> <snip>
Current Time: Mon Apr 19 18:27:19 GMT 2021
Powered by FUDForum. Page generated in 0.02776 seconds
