Re: Drill-Through [message #680746 is a reply to message #677758] |
Thu, 09 June 2011 16:00 |
Jeyinul,
I did not see any issues with the master report. Any chance you could
build the master and detail report using the sampledb and produce the
problem. That way I can run and debug the report.
Jason
On 6/9/2011 6:20 AM, jeyinul wrote:
> Hi All,
> Now I am trying to use Drill-Through option in Hyperlink.
> i have two reports. i am trying to connect one report using drill-through.
> Its working fine in BIRT.
> When i deployed the report i am getting error when i click the hyperlink
> saying that "Keys Manipulated"
> i.e. First report is working fine. it displays correct records. in that
> records, one column is having hyperlink to connect another report.
> here is the problem.
> Can you help me on this.
> Jeyinul.
Re: Drill-Through [message #682188 is a reply to message #681952] |
Fri, 10 June 2011 15:00 |
Can you attach the detail report as well?
Jason
On 6/10/2011 2:10 AM, jeyinul wrote:
> Hi Jason,
> I have tried using Sample database.
> But I am getting same error. when i click the hyperlink.
> Here i attached the report. Please check and let me know.
> Thanks.
> Jeynul.
Re: Drill-Through [message #683308 is a reply to message #683154] |
Mon, 13 June 2011 13:36 |
Jeyinul
Do you have the detail report that uses the sample db? If so please
post it. I want to be able to produce the issue. Where are you
deploying the reports?
Jason
On 6/13/2011 1:47 AM, jeyinul wrote:
> Hi Jason,
> Please find the attachment foe detail report.
> Jeyinul.
Re: Drill-Through [message #683840 is a reply to message #683627] |
Tue, 14 June 2011 13:40 |
Jeyinul,
I am not familiar with that tool. Have you posted the question on their
forums?
Jason
On 6/14/2011 2:15 AM, jeyinul wrote:
> Hi Jason,
> We are using a tool which is called "DIGITE"
> Generally we need RPT file and reg.jsp file to generate a report.
> RPT FILE IS POSTED ABOVE.
> The below code, i am using.
> 1.IN reg.jsp,
> <!-- 1. Include com.tufan.digite.utils.webappsecurityutils.* in your JSP
> <%@ page import ="com.tufan.digite.utils.webappsecurityutils.*"%>
> <%@ page import ="com.tufan.digite.web.beans.*"%>
> <%@ page import ="com.tufan.digite.dataobjects.*"%>
> WebSecHelper.checkIfSubmitIsGenuine(request, response,application);
> <html>
> <title> Table </title>
> <body>
> <form name = "j">
> <TABLE width ="350" align = "center" BORDER="1" BGCOLOR="#F9A89F"
> height="60">
> <tr>
> <td> Project Name: <input type="text" name="SearchParam" /> </td>
> </tr>
> </table>
> </form>
> </body>
> </html>
> Plz check and let me know.
> Jeyinul
Re: Drill-Through [message #685428 is a reply to message #685230] |
Fri, 17 June 2011 13:47 |
Jeyinul,
I would like to help, but I do not know how the DIGITE package is
integrating BIRT.
Jason
On 6/17/2011 12:32 AM, jeyinul wrote:
> Hi Jason,
> I am getting following message in console while running the report.
> Can you please try to solve my problems,
> ignoring unsupported operation exception thrown by ODA driver
> (org.eclipse.birt.report.data.oda.jdbc) cannot set query specification
> before prepare.
> EXCEPTION IN WEBSECHELPER.validatekeyparametersForURL()
> java.lang.exception:Keys Manipulated
> Regards,
> Jeyinul.
FUDForum. Page generated in 0.04348 seconds
