Home » Modeling » GMF (Graphical Modeling Framework) » why save failed
icon9.gif  why save failed [message #677676] Thu, 09 June 2011 02:42 Go to next message
hi,
I use GMF to develope a modeling tool,
i got a trouble that when i adjust the connection Anchor,from p1 index.php/fa/2980/0/to p2index.php/fa/2981/0/
by set the sourceAnchor and targetAnchor
			EllipseAnchor sourceAnchor = new EllipseAnchor((IFigure)sep.getFigure());
			EllipseAnchor targetAnchor = new EllipseAnchor((IFigure)tep.getFigure());
			connectionEditpart.getConnectionFigure().setSourceAnchor(sourceAnchor);
			connectionEditpart.getConnectionFigure().setTargetAnchor(targetAnchor);
it seems worked,but when i save and close the diagram and reopen it,it still not changed(as p1),
i examed the diagram file with UltraEdit,i see it has not been changed
so,why it obviously changed successfully in the canvas,but in the file,it was not changed at all?
(i tried 2 ways to save ,but it does'not work:
1 currentDiagramEditor.doSave
2 ctrl+s in the editer UI
and i failed)
thanks.
  • Attachment: 1.jpg
    (Size: 4.40KB, Downloaded 484 times)
  • Attachment: 2.jpg
    (Size: 4.04KB, Downloaded 474 times)
Re: why save failed [message #677748 is a reply to message #677676] Thu, 09 June 2011 05:25 Go to previous messageGo to next message
If you modify directly the figures, there state is not persisted in the diagram file. You have to use a SetConnectionAnchorCommand to perform this operation. It will apply changes on both diagram editor and underlying diagram model.
HTH
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/BPM_download.php
Eclipse Community Award 2011: Best Modeling Tool
Re: why save failed [message #681896 is a reply to message #677748] Thu, 09 June 2011 23:06 Go to previous messageGo to next message
thank you,Mickael.
um.."there state is not persisted in the diagram file",thanks for advice and it seems accurate and right.
but,when I tried to use "SetConnectionAnchorCommand" ,i found seems there is no such method or "ChangeConnectionAnchorCommand" in this framework
then i think maybe I should use "ChangePropertyValueRequest" but it seems it can change some infomation but not ConnectionAnchor,so I am confused again.
Re: why save failed [message #682065 is a reply to message #681896] Fri, 10 June 2011 06:03 Go to previous messageGo to next message
Sorry, I should have written SetConnectionAnchorsCommand (with a S after Anchor).
Le 10/06/2011 05:06, xebec a écrit :
> thank you,Mickael.
icon14.gif  Re: why save failed [message #683219 is a reply to message #682065] Mon, 13 June 2011 05:07 Go to previous message
"SetConnectionAnchorsCommand"
cool..it worked!I confused in this problem for several days until your instruct helped me Razz
thank you,very much,Mickael
Previous Topic:Extend / Inherit Diagrams
Next Topic:Hiding and unhiding elements / editparts
Current Time: Thu Nov 06 20:24:22 EST 2025
Powered by FUDForum. Page generated in 0.03514 seconds
