Home » Language IDEs » ServerTools (WTP) » Publish Exploded WAR(How to configure Jboss v5.0 server to publish exploded wars)
Publish Exploded WAR [message #677454] Wed, 08 June 2011 15:06 Go to next message
Duncan Krebs is currently offline Duncan KrebsFriend
Member
I'm working to get my environment setup and have a question regarding development with jboss using the WTP. I'm close the only thing I need is for Eclipse to publish the war files in the jboss deployment directory as exploded in directory format not a .war file because the apps I'm working with require it. Does anyone know how I can tell or configure Eclipse to say please publish as exploded!!? - Duncan
Re: Publish Exploded WAR [message #677493 is a reply to message #677454] Wed, 08 June 2011 16:49 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry IsaacsFriend
On 6/8/2011 11:06 AM, Duncan Krebs wrote:
> Hi, I'm working to get my environment setup and have a question
With the JBoss support built into WTP, you can't. The Generic Server
support upon which the JBoss support is built, always publishes a war
file to a directory where it is assumed that the server will auto-serve
this war.
You may want to investigate JBossAS Tools, which offers JBoss server
support in Eclipse that is better integrated than what is currently
offered via the WTP Generic Server support. I believe it offers
incremental publishes, i.e. you change a JSP and only that JSP is
published. It doesn't have to rebuild a war to update a single changed
JSP. This would imply it can serve an exploded webapp.
Larry
Re: Publish Exploded WAR [message #684949 is a reply to message #677454] Thu, 16 June 2011 14:09 Go to previous message
Wolfgang Knauf is currently offline Wolfgang KnaufFriend
Member
Hi Duncan,
I have a modified JBoss plugin here: http://www.cs.hs-rm.de/~knauf/public/
It has (among other small enhancements) a very dirty workaround to
perform exploded deployment (by just unzipping the WTP created archive
and copying it to JBoss ;-)).
If JBossTools is a too big change for you, you might use this plugin. Of
course, my approach does not provide the best performance ;-)
Best regards
Wolfgang
Previous Topic:Multiple sourceElementParsers extensions per project
Next Topic:Error messages with (X)HTML / JSP
Current Time: Mon Mar 08 07:29:22 GMT 2021
Powered by FUDForum. Page generated in 0.01923 seconds
