Home » Eclipse Projects » Rich Client Platform (RCP) » re-factoring rcp application structure(from one bundle to several bundles)
re-factoring rcp application structure [message #677368] |
Wed, 08 June 2011 10:15 |
Luca Ferrari Messages: 159 Registered: November 2009 |
Hi all,
I've developed an RCP application as a single huge plugin, now I'd like to open source it and to make it cleaner, so I decided to split it into different plugins, in order to separate and modularise functionalities and features.
The first step I did was to create a new project, called "WHR.lib" which is a plugin project without an activator and that includes all the jars required by my application. I exported the packages provided by such jars.
In the main project, "WHR.core", I removed all the jars and imported in the required plugins the WHR.lib project, and also added the dependecy to such project int he build path.
However I've got a problem when I launch the application from the plugin.xml:
!SESSION 2011-06-08 12:03:42.149 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_23
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
Framework arguments: -application WHR.core.application
Command-line arguments: -application WHR.core.application -data /sviluppo/java/eclipseWorkspace/../runtime-WHR.core.application -dev file:/sviluppo/java/eclipseWorkspace/.metadata/.plugins/org.eclipse.pde.core/WHR.core.application/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.osgi 2 0 2011-06-08 12:03:47.208
!MESSAGE The activator whr.rcp.Activator for bundle WHR.core is invalid
!STACK 0
org.osgi.framework.BundleException: The activator whr.rcp.Activator for bundle WHR.core is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:157)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:751)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:408)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:238)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1193)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:189)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.ClassNotFoundException: whr.rcp.Activator
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:494)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:326)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:150)
... 23 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2011-06-08 12:03:47.230
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in WHR.core was unable to load class whr.rcp.Application.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:162)
Caused by: java.lang.ClassNotFoundException: whr.rcp.Application
... 16 more
The system alerts me that there are problems, and the problem view shows me the following:
Description Resource Path Location Type
classpath error: unable to find org.aspectj.lang.JoinPoint (check that aspectjrt.jar is in your classpath) WHR.core Unknown Java Problem
However the lib project exports the org.aspectj.lang package and in the Java editor I don't see any error against the org.aspectj.lang imports. The following an excerpt of theexport section of the WHR.lib MANIFEST.MF
Export-Package: org.aopalliance.aop,
org.aspectj.lang,
In the classpath section of the WHR.core project (the one I launch) I don't have anything, and I cannot specify the packages of the WHR.lib project. With regard to the running application I've got the following configuration:
<extension
id="application"
point="org.eclipse.core.runtime.applications">
<application>
<run
class="whr.rcp.Application">
</run>
</application>
</extension>
and the manifest is
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: WHR.core
Bundle-SymbolicName: WHR.core;singleton:=true
Bundle-Version: 0.6.5.alpha
Bundle-Activator: whr.rcp.Activator
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.core.databinding;bundle-version="1.2.0",
org.eclipse.jface.databinding;bundle-version="1.3.1",
org.junit,
WHR.lib;bundle-version="1.0.0"
Bundle-ActivationPolicy: lazy
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Bundle-ClassPath: classes/,
conf/,
img/
And finally the following is the activator of WHR.core:
public class Activator extends AbstractUIPlugin {
// The plug-in ID
public static final String PLUGIN_ID = "WHR.core";
* A global image registry for the application.
private ImageRegistry imageRegistry = null;
// The shared instance
private static Activator plugin;
public Activator() {
public void start(BundleContext context) throws Exception {
super.start(context);
plugin = this;
public void stop(BundleContext context) throws Exception {
plugin = null;
super.stop(context);
// clean the registry
if( this.imageRegistry != null )
this.imageRegistry.dispose();
this.imageRegistry = null;
public static Activator getDefault() {
return plugin;
public static ImageDescriptor getImageDescriptor(String path) {
return imageDescriptorFromPlugin(PLUGIN_ID, path);
public synchronized final ImageRegistry getImageRegistry() {
// return the value of the this.imageRegistry field
return this.imageRegistry;
public synchronized final void setImageRegistry(ImageRegistry imageRegistry) {
// set the value of the this.imageRegistry field
this.imageRegistry = imageRegistry;
Finally, I've tried to start the application with -clean, but nothing changed.
Anybody has a clue?
Re: re-factoring rcp application structure [message #678805 is a reply to message #677423] |
Thu, 09 June 2011 14:57 |
This is the build.properties files:
output.. = classes/
bin.includes = plugin.xml,\
META-INF/,\
classes/,\
plugin_customization.ini,\
img/,\
splash.bmp,\
src/,\
conf/
I've recomputed the include path of each plugin but the error is still the same, and even the package explorer still reports the error that org.aspectj.lang.JoinPoint cannot be found.
I've checked and the project is configured as aspectj project. What has so strange my classpath?
Finally, I'll separate each jar into their own projects as soon as I can run it again.
Any suggestion is appreciated.
Re: re-factoring rcp application structure [message #682115 is a reply to message #678805] |
Fri, 10 June 2011 12:50 |
Your bin.includes isn't set up like a normal bundle. What about:
source.. = src/
output.. = classes/
META-INF/,\
img/,\
splash.bmp,\
conf/
Bundle-ClassPath: .,
conf/,
img/
Why is conf and img in your bundle classpath? That means the are treated as roots for classloading. Putting the . everywhere will make sure it's included correctly.
However, I'm not sure why your project is in that shape to begin with. You mentioned using AspectJ, are you doing runtime weaving? Maybe that needs the src/ directory in your binary plugin, I don't know.
Paul Webster
Current Time: Fri Apr 19 19:23:03 GMT 2024
Powered by FUDForum. Page generated in 0.03096 seconds
