Importing packages into a 3rd party bundle: Virgo doesn't pick up my fragment bundle? [message #676904] |
Mon, 06 June 2011 22:12 |
Hi all,
I'm having troubles with Virgo picking up my fragment bundle.
I created it following Importing packages into a 3rd party bundle from the FAQ.
In Eclipse "File>New>Bundle Project"
Changed manifest to:
Manifest-Version: 1.0
Bundle-Version: 1.0.0
Bundle-Name: org.springframework.orm_3.0.5.RELEASE_fix
Bundle-ManifestVersion: 2
Bundle-SymbolicName: com.prefabosft.org.springframework.orm.fix
Fragment-Host: org.springframework.orm;version="[3.0.5.RELEASE,3.0.5.RELEASE]"
Import-Bundle: com.springsource.javax.persistence;version="[2.0.0.Beta1,2.0.0.Beta1]"
Excluded-Imports: com.springsource.javax.persistence;version="[1.0.0,1.0.0]"
And while deploying (both Debug-on-server from Eclipse as dropping the jar in repository/user) I don't get any sign from Virgo picking it up nor seeing the fragment in the web admin gui.
All comments more than welcome!
Jochen
Re: Importing packages into a 3rd party bundle: Virgo doesn't pick up my fragment bundle? [message #677030 is a reply to message #676994] |
Tue, 07 June 2011 11:11 |
Hristo Iliev wrote on Tue, 07 June 2011 01:25Hi Jochen,
Are there any logs in serviceability that can help diagnose the issue?
Hristo Iliev
I know for sure that the serviceability/logs/log.log doesn't record anything...the jar is totally ignored as it seems. (which could be, as Glyn states, because of a malformed manifest)
So this technique is perhaps not suitable for swapping imports from an existing bundle? (and only for adding imports?)
As hacking bundle manifests obviously is not an ideal practice of course. (I'm trying to run a (Spring Roo generated) test webapp inside Virgo, and started dismantling the pom, moving dependencies to the manifest)
Grts
Re: Importing packages into a 3rd party bundle: Virgo doesn't pick up my fragment bundle? [message #677168 is a reply to message #677030] |
Tue, 07 June 2011 18:48 |
The OSGi specification (3.13 Fragment Bundle) allows appending of import definitions , Require-Bundle entries and export definitions of a Fragment bundle to the host bundle.
There are some restrictions so perhaps you hit one of them (conflicting imports) with what you have in the manifest.
I've tried the scenario but every time I got errors in the logs. Can you create a bug with reproducible scenario where the logs are missing so we can improve the diagnostics?
Re: Importing packages into a 3rd party bundle: Virgo doesn't pick up my fragment bundle? [message #677249 is a reply to message #677168] |
Tue, 07 June 2011 22:36 |
Hristo Iliev wrote on Tue, 07 June 2011 14:48The OSGi specification (3.13 Fragment Bundle) allows appending of import definitions , Require-Bundle entries and export definitions of a Fragment bundle to the host bundle.
* I created a made a clean install (unzip) of Virgo M5 tomcat.
* Started it in debug. Did a "tail -f" on ../logs/log.log
* Then I deployed my fragment (git://github.com/JochenSzostek/org.springframework.orm_3.0.5.RELEASE_fix.git) using STS
* log file didn't output anything.
The GIT project is minimal as it's only my (probably malformed) manifest actually in an Eclipse project.
Hope that helps, and if not just let me know. I'd be glad to help.
Best wishes,
Jochen
ps: Do you want me to Jira/Bugzilla it somewhere perhaps?
Re: Importing packages into a 3rd party bundle: Virgo doesn't pick up my fragment bundle? [message #681754 is a reply to message #677316] |
Thu, 09 June 2011 19:29 |
I created a bug here https://bugs.eclipse.org/bugs/show_bug.cgi?id=348949
Though deployment into pickup did produce logging output:
[2011-06-09 21:25:20.129] INFO fs-watcher org.eclipse.virgo.medic.eventlog.default HD0001I Hot deployer processing 'CREATED' event for file 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT.jar'.
[2011-06-09 21:25:20.130] INFO fs-watcher o.e.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener ApplicationDeploying path 'D:\dev\server\virgo-tomcat-server-3.0.0.M05\pickup\org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT.jar'.
[2011-06-09 21:25:20.189] INFO fs-watcher o.e.v.k.m.i.deployer.ModelInstallArtifactLifecycleListener Processing installing event for bundle 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT' version '0.0.0'
[2011-06-09 21:25:20.193] INFO fs-watcher org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT' version '0.0.0'.
[2011-06-09 21:25:20.196] INFO fs-watcher o.e.virgo.kernel.userregion.internal.quasi.DependencyCalculator Calculating missing dependencies of bundle(s) 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0'
[2011-06-09 21:25:20.201] INFO fs-watcher o.e.virgo.kernel.userregion.internal.quasi.DependencyCalculator The dependencies of '[org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0]' are '[]'
[2011-06-09 21:25:20.203] INFO fs-watcher o.eclipse.virgo.kernel.model.internal.bundle.ModelBundleListener Processing installed event for bundle 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT:0.0.0' in region 'org.eclipse.virgo.region.user'
[2011-06-09 21:25:20.205] INFO fs-watcher org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT' version '0.0.0'.
[2011-06-09 21:25:20.205] INFO fs-watcher o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [Virgo Kernel Deployer (org.eclipse.virgo.kernel.deployer)]' popped and set to 'BundleDelegatingClassLoader for [Virgo Kernel Deploy
[2011-06-09 21:25:20.208] INFO fs-watcher o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [Virgo Kernel Deployer (org.eclipse.virgo.kernel.deployer)]' pushed and set to 'KernelBundleClassLoader: [bundle=org.springframework
[2011-06-09 21:25:20.208] INFO fs-watcher o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [Virgo Kernel D
[2011-06-09 21:25:20.211] INFO fs-watcher o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [Virgo Kernel Deployer (org.eclipse.virgo.kernel.deployer)]' pushed and set to 'KernelBundleClassLoader: [bundle=org.springframework
[2011-06-09 21:25:20.211] INFO fs-watcher o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0]' pushed and set to 'KernelBundleClassLoader: [bundle=org.springfram
[2011-06-09 21:25:20.212] INFO fs-watcher org.eclipse.virgo.kernel.core.internal.BundleStartTracker Adding signal 'org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal@273e07bd' for bundle 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0
[103]'
[2011-06-09 21:25:20.212] INFO fs-watcher o.e.v.k.i.a.internal.AtomicInstallArtifactLifecycleListener No atomic parent of bundle 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT' version '0.0.0' in scope 'null' to propagate starting event to
[2011-06-09 21:25:20.213] INFO fs-watcher org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT' version '0.0.0'.
[2011-06-09 21:25:20.213] INFO fs-watcher org.eclipse.virgo.kernel.core.internal.BundleStartTracker Non-Spring DM powered bundle 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0 [103]' has started. Driving signals '[org.eclipse.virgo.kernel.install.artifact.internal.AbstractIns
tallArtifact$StateMonitorSignal@273e07bd]'.
[2011-06-09 21:25:20.214] INFO start-signalling-5 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Driving signal 'org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal@273e07bd'
[2011-06-09 21:25:20.214] INFO fs-watcher o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=org.springfram
[2011-06-09 21:25:20.214] INFO start-signalling-5 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0]' pushed and set to 'KernelBundleClassLoader: [bundle=org.springfram
[2011-06-09 21:25:20.215] INFO fs-watcher o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [Virgo Kernel D
[2011-06-09 21:25:20.216] INFO start-signalling-5 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT' version '0.0.0'.
[2011-06-09 21:25:20.216] INFO start-signalling-5 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=org.springframework.orm_3.0.5.RELEASE_fix-0.0.1-SNAPSHOT_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=org.springfram
Hope that helps,
Jochen
FUDForum. Page generated in 0.04120 seconds
