Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Disabled menu item icons missing with Windows Classic theme
Disabled menu item icons missing with Windows Classic theme [message #676595] Sun, 05 June 2011 15:10 Go to next message
Stanimir Stamenkov is currently offline Stanimir StamenkovFriend
It appears the icons for disabled menu items are not rendered,
unless the item get selected:
http://i.imgur.com/QS0qu.png
http://i.imgur.com/eZt1b.png
The case appears with Windows Classic theme. Using Windows Aero
theme all the icons appear visible:
http://i.imgur.com/uZaYZ.png
Is it a platform limitation or omission?
Stanimir
Re: Disabled menu item icons missing with Windows Classic theme [message #676763 is a reply to message #676595] Mon, 06 June 2011 12:56 Go to previous messageGo to next message
Lakshmi P ShanmugamFriend
I'm unable to see this problem on my Vista machine with Windows Classic Theme.
Are you using Windows 7 or Vista? Which version of eclipse?
Lakshmi P Shanmugam
Re: Disabled menu item icons missing with Windows Classic theme [message #676829 is a reply to message #676763] Mon, 06 June 2011 16:32 Go to previous messageGo to next message
This seems to happen with the eclipse 3.7 builds but it works fine in eclipse 3.6.2. Please open a bug report in SWT so that it can be investigated --> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT
Thanks.
Lakshmi P Shanmugam
Re: Disabled menu item icons missing with Windows Classic theme [message #676909 is a reply to message #676829] Mon, 06 June 2011 22:35 Go to previous message
Mon, 06 Jun 2011 22:02:59 +0530, /Lakshmi Shanmugam/:
> investigated -->
> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=SWT
Yes, I should have given I've tried with Eclipse 3.7 build, and
should have tried it is different with Eclipse 3.6.2 to mention it.
I've now filled:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=348481
Stanimir
Previous Topic:Building a standalone SWT application
Next Topic:LabelProvider with image disables expansion of checkbox tree nodes
Current Time: Sat Mar 06 06:47:04 GMT 2021
Powered by FUDForum. Page generated in 0.02506 seconds
