Installation problem [message #676385] |
Sat, 04 June 2011 04:09 |
Hello. I hope any of you be so kind to help me with my problem. I had to install Eclipse and all of the plugins I used (ATL, UML2 Tools and Papyrus). The installation of Papyrus failed. I tride two methods:
1. Using Help->Install Modeling Component
2. Using Help->Install New Software...
When using the second option I got the messages below. I tried to install the package EPF but cannot find it. Does any of you know the solution to my problem? I really appreciate your help, since I am novice in Eclipse.
Cannot complete the install because one or more required items could not be found.
Software being installed: MDT Papyrus - SDK: Runtime, Tools, Documentation and sources (Incubation) 0.7.3.v201104270854 (org.eclipse.papyrus.sdk.feature.group 0.7.3.v201104270854)
Missing requirement for filter properties ~= $0: EPF Richtext 1.6.0.201101131810 (org.eclipse.epf.richtext.feature.group 1.6.0.201101131810) requires 'org.eclipse.epf.common.win32.win32.x86 [1.5.0.201101131810]' but it could not be found
Cannot satisfy dependency:
From: MDT Papyrus - Backbone (Incubation) 0.7.3.v201104270854 (org.eclipse.papyrus.backbone.feature.group 0.7.3.v201104270854)
To: org.eclipse.epf.richtext.feature.group [1.6.0.201101131810]
From: MDT Papyrus - Runtime and Tools (Incubation) 0.7.3.v201104270854 (org.eclipse.papyrus.feature.group 0.7.3.v201104270854)
To: org.eclipse.papyrus.backbone.feature.group [0.7.3.v201104270854]
From: MDT Papyrus - SDK: Runtime, Tools, Documentation and sources (Incubation) 0.7.3.v201104270854 (org.eclipse.papyrus.sdk.feature.group 0.7.3.v201104270854)
To: org.eclipse.papyrus.feature.group [0.7.3.v201104270854]
/TB
Re: Installation problem [message #677561 is a reply to message #676385] |
Wed, 08 June 2011 20:22 |
Yann Tanguy Messages: 80 Registered: July 2009 |
Member |
I just tried the following install procedure without trouble (on win7):
- Download Eclipse Modeling Helios SR2 (32 Bit version)
- Help / Install Modeling Components
- Just select Papyrus (its 0.7.3.v201104270854),
- Validate everything, and reboot
- Help / Install New Software
- Add update site : "http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/helios"
- Only select "MDT Papyrus - SDK: Runtime..."
- Validate everything and reboot
Maybe I'm wrong but the EPF plug-in required by Papyrus might be platform dependent and causing issues with install on Windows 64 Bit version of eclipse, Linux or MacOS.
[Updated on: Wed, 08 June 2011 20:26] Report message to a moderator
Re: Installation problem [message #677587 is a reply to message #677330] |
Wed, 08 June 2011 21:40 |
Hello Sebastien
Unfortunately I still have problems. I installed Helios Service Release 2 Build id: 20110218-0911 (the x86-64 version of Eclipse Helios) and still getting the same error messages:
1. When I select Help->Install Modeling Components I get
Problems occurred while performing installation: Operation details
2. When I select Help->Install New Software... I get the messages below when trying to install Papyrus All (0.7.3.v201104270854).
I found a thread in this forum where the same issue is addressed, but no solution was reported other than switching to the 32-bit version of Eclipse Helios.
Thank you. Kindest regards.
/TB
Re: Installation problem [message #690013 is a reply to message #677330] |
Tue, 28 June 2011 19:05 |
I have this installation problem when trying to install the release 0.7.3.v201104270854. I have just realized that there are a number of builds corresponding to the release 0.8.0. Does this release 0.8.0 fix any of the installation issues? If so I will download it and install it.
/TB
FUDForum. Page generated in 0.03699 seconds
