Home » Eclipse Projects » Eclipse Platform » ProjectExplorer and Navigator disappeared(Something went wrong during an update! How do I recover?)
ProjectExplorer and Navigator disappeared [message #676340] |
Fri, 03 June 2011 19:41 |
Mark Mising name Messages: 73 Registered: July 2009 Location: Ohio, USA |
Member |
Hi, I updated Eclipse today through the "Check for Updates" menu. Afterwards, I seem to have lost the plugin for the ProjectExplorer (and perhaps others). I can't even find it to relaunch it from the list of available views. How do I get it back?? Go through the whole update process again? Or is there a simpler way??
Here's some background as to why updating Eclipse is no easy task...
I don't update Eclipse very often because my development box does not have Internet access. When I do update, I have a short window of time (few hours) only on certain days where the electronics technicians have to unmount filesystems, unplug the network, plug in the Internet (which is not much better than dial-up speed), and go through other hoops so I can use Eclipse's built-in update mechanism, then reverse it all when I'm done -- a major pain that involves time and coordination among several people!
Today's update seemed to succeed without a hitch (no errors reported; normal behavior), except that after a restart of Eclipse, I noticed my Project Explorer window went away. I paid little attention hoping that this was an artifact of being outside my usual environment (losing filesystem mounts, etc.).
So, after being taken off the Internet and restored back to my normal environment, launching Eclipse revealed a continuation of the same problem. I also noticed other functional limitations, like the inability to switch perspectives, and a blank Navigator window. Some of the errors reported suggest that the problem is that the org.eclipse.ui.navigator.ProjectExplorer plugin is not available. Indeed, I did not see anything similar in the plugins subdirectory, so I'm thinking that I can repair Eclipse by putting the plugin back into that directory.
How can I get the plugin(s) I need without having to give my computer Internet access again? I'd like to try simply downloading the needed file(s) and copying them to the plugins directory. My question is, where can I get just the plugins I need??
Mark
[Updated on: Fri, 03 June 2011 19:50] Report message to a moderator
Re: ProjectExplorer and Navigator disappeared [message #676469 is a reply to message #676340] |
Sat, 04 June 2011 16:32 |
Ed Merks Messages: 33140 Registered: July 2009 |
Mark,
Deleting your <workspace>/.metadata/.log and running eclipse with -clean
-debug might help produce a more detailed log that describes any
conflicts (problems with bundle version ranges) in what's been installed.
Updates don't generate delete anything (they just copy in new versions
that, because they have a higher version number, are generally favored
over older versions) so I'd be surprised if something literally has gone
missing...
> (and perhaps others). How do I get them back?? Go through the whole
> that directory.
> Mark
Ed Merks
Current Time: Wed Apr 24 14:21:30 GMT 2024
Powered by FUDForum. Page generated in 0.03356 seconds
