Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Vertical ToolBar(How do I prevent multiple columns on a vertical ToolBar?)
Vertical ToolBar [message #675813] Wed, 01 June 2011 15:31
Mario Marinato is currently offline Mario MarinatoFriend
Member
I'm creating a vertical ToolBar:
ToolBar toolBar = new ToolBar( parent, SWT.RIGHT | SWT.VERTICAL );
And then adding items to it:
for ( MyObject myObject: myObjects ) {
    ToolItem toolItem = new ToolItem( toolBar, SWT.NONE );
    toolItem.setText( myObject.getLabel() );
    toolItem.setImage( myObject.getImage() );
The toolbar is created correctly, but as some labels are too long, there are some cases in which new items are created on a second column, in front of the previous item.
So, instead of getting a toolbar that looks like
Item with a very long label
Tiny item
Little item
I get a toolbar that looks like
Tiny item                    Little item
If the long label is long enough, a third column will appear.
Does anyone know if there's a way to prevent the creation of a new column on the toolbar?
Thank you.
Mário Marinato
from Brazil
Previous Topic:Layout woes
Next Topic:SWT ExpandItem widget layout/size problem
Current Time: Wed Jan 27 22:27:04 GMT 2021
Powered by FUDForum. Page generated in 0.01885 seconds
