Re: Counting on a xml data sources [message #675489 is a reply to message #675462] |
Tue, 31 May 2011 16:12 |
Is value a column in your dataset? If so you should be able to add a
computed column to the dataset that does a count and add a filter to the
computed column on value == yes. If you have a test xml file and simple
report post it and I can modify it for you.
Jason
On 5/31/2011 11:26 AM, forums-noreply@eclipse.org wrote:
> Hi there !
> I'm trying to make a report from a Xml data sources.
> I've got a xml file full or things like
> <answer value="yes" from="client1" uselessdata="xxx" />
> <answer value="no" from="client2" uselessdata="xxx" />
> I was able to make a Data set, allowing me to make a table with all the
> answer "yes" and who made it.
> But now i would like to count how many "yes", and how many "no" there
> is, but i don't know how do that, and where i have to do that.
> I know a sql request can do that, but Xpath seems to be less powerful.
> Can someone help me ?
> Thanks !
FUDForum. Page generated in 0.02844 seconds
