Build fails with ClassNotFoundException: org.eclipse.buckminster.ant.support.AntBuildLogger [message #674660] |
Fri, 27 May 2011 18:57 |
Since this afternoon my build keeps failing with this exception:
[echo] Performing org.eclipse.emf.cdo.site#site.p2
[java] INFO: [start org.eclipse.emf.cdo.license:eclipse.feature$4.0.0.qualifier#manifest]
[java] ERROR: The library "ant_tasks/ant_tasks.jar" specified from "org.eclipse.buckminster.ant" for the antTasks or antTypes extension does not exist
[java] ERROR: The library "ant_tasks/ant_tasks.jar" specified from "org.eclipse.buckminster.jdt" for the antTasks or antTypes extension does not exist
[java] ERROR: The library "ant_tasks/ant_tasks.jar" specified from "org.eclipse.buckminster.pde" for the antTasks or antTypes extension does not exist
[java] ERROR: The library "ant_tasks/ant_tasks.jar" specified from "org.eclipse.buckminster.ant" for the extraClasspathEntries extension does not exist
[java] ERROR: Unable to instantiate logger: org.eclipse.buckminster.ant.support.AntBuildLogger
[java] ERROR: org.eclipse.core.runtime.CoreException: Unable to instantiate logger: org.eclipse.buckminster.ant.support.AntBuildLogger
[java] org.eclipse.core.runtime.CoreException: Unable to instantiate logger: org.eclipse.buckminster.ant.support.AntBuildLogger
[java] at org.eclipse.buckminster.ant.AntRunner.handleInvocationTargetException(AntRunner.java:167)
[java] at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:322)
[java] at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(AntActor.java:254)
[java] at org.eclipse.buckminster.core.actor.AbstractActor.perform(AbstractActor.java:195)
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager$DirectActionInvocation.execute(PerformManager.java:143)
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager.internalPerform(PerformManager.java:454)
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:293)
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:305)
[java] at org.eclipse.buckminster.core.commands.Perform.internalRun(Perform.java:108)
[java] at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:91)
[java] at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:200)
[java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:317)
[java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:136)
[java] at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:156)
[java] at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
[java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
[java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
[java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
[java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[java] at java.lang.reflect.Method.invoke(Method.java:597)
[java] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
[java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
[java] at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
[java] at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
[java] Caused by: Unable to instantiate logger: org.eclipse.buckminster.ant.support.AntBuildLogger
[java] at org.eclipse.ant.internal.core.ant.InternalAntRunner.createLogger(InternalAntRunner.java:753)
[java] at org.eclipse.ant.internal.core.ant.InternalAntRunner.addBuildListeners(InternalAntRunner.java:200)
[java] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:570)
[java] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:496)
[java] at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:318)
[java] ... 25 more
[java] Caused by: java.lang.ClassNotFoundException: org.eclipse.buckminster.ant.support.AntBuildLogger
[java] at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
[java] at java.security.AccessController.doPrivileged(Native Method)
[java] at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
[java] at org.eclipse.ant.internal.core.AntClassLoader.findClass(AntClassLoader.java:54)
[java] at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
[java] at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
[java] at java.lang.Class.forName0(Native Method)
[java] at java.lang.Class.forName(Class.java:169)
[java] at org.eclipse.ant.internal.core.ant.InternalAntRunner.createLogger(InternalAntRunner.java:745)
[java] ... 33 more
[java] ... 25 more
[java] ... 33 more
Example: https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1493/console
Please help!
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: Build fails with ClassNotFoundException: org.eclipse.buckminster.ant.support.AntBuildLogger [message #674739 is a reply to message #674660] |
Sat, 28 May 2011 06:41 |
Hi Eike,
This is all very odd. I'm looking at this URL:
https://hudson.eclipse.org/hudson/job/emf-cdo-integration/ws/tools/buckminster/plugins/org.eclipse.buckminster.ant_1.2.360.r11760/
which is your installed 'org.eclipse.buckminster.ant' plugin. For some reason it lacks the ant_tasks folder which
results in the errors below. The same is true for the corresponding jdt and pde plugins. I tried installing the exact
same version from our update site and that worked just fine. The ant_tasks folders are indeed present.
I'll continue investigating and try to find the cause of this. One theory is that it as something to do with pack200 and
that unpacking somehow fails on nested jar files.
- thomas
On 2011-05-27 20:57, Eike Stepper wrote:
> [java] at
> [java] ... 25 more
> [java] ... 33 more
> [java] at
> [java] ... 25 more
> [java] ... 33 more
> Please help!
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: Build fails with ClassNotFoundException: org.eclipse.buckminster.ant.support.AntBuildLogger [message #674743 is a reply to message #674739] |
Sat, 28 May 2011 07:32 |
Am 28.05.2011 08:41, schrieb Thomas Hallgren:
> Hi Eike,
> which is your installed 'org.eclipse.buckminster.ant' plugin. For some reason it lacks the ant_tasks folder which results in the errors below. The same is true for the corresponding jdt and pde plugins. I tried installing the exact same version from our update site and that worked just fine. The ant_tasks folders are indeed present.
> I'll continue investigating and try to find the cause of this. One theory is that it as something to do with pack200 and that unpacking somehow fails on nested jar files.
Thanks, Thomas. Let me know if you'd like me to file a bugzilla.
Cheers
/Eike
> - thomas
>> Hi,
>> [java] at
>> [java] ... 25 more
>> [java] ... 33 more
>> [java] at
>> [java] ... 25 more
>> [java] ... 33 more
>> Please help!
>> Cheers
>> /Eike
Cheers
/Eike
Re: Build fails with ClassNotFoundException: org.eclipse.buckminster.ant.support.AntBuildLogger [message #674944 is a reply to message #674743] |
Sun, 29 May 2011 16:22 |
Hi Eike,
It was a glitch in our build that caused this. It wasn't obvious since I needed three builds to reproduce it.
Build 1, produced a Buckminster with the glitch.
Build 2, performed with the Buckminster from build 1 succeeds but produces the culprit for your problem.
Build 3, performed with the Buckminster from build 2 fails with the error you just got.
The one that is now published to our update sites is OK. It has gone through all iterations.
- thomas
>> Hi Eike,
> Cheers
> /Eike
>> - thomas
>>> Hi,
>>> [java] at
>>> [java] ... 25 more
>>> [java] ... 33 more
>>> [java] at
>>> [java] ... 25 more
>>> [java] ... 33 more
>>> Please help!
>>> Cheers
>>> /Eike
Re: Build fails with ClassNotFoundException: org.eclipse.buckminster.ant.support.AntBuildLogger [message #675360 is a reply to message #674944] |
Tue, 31 May 2011 09:08 |
Thank you, Thomas. I could verify that it now works again.
Cheers
/Eike
Am 29.05.2011 18:22, schrieb Thomas Hallgren:
> Hi Eike,
> - thomas
>>> Hi Eike,
>> Cheers
>> /Eike
>>> - thomas
>>>> Hi,
>>>> [java] at
>>>> [java] ... 25 more
>>>> [java] ... 33 more
>>>> [java] at
>>>> [java] ... 25 more
>>>> [java] ... 33 more
>>>> Please help!
>>>> Cheers
>>>> /Eike
Cheers
/Eike
FUDForum. Page generated in 0.03271 seconds
