Home » Modeling » Graphiti » Trying to get the sample to work
Trying to get the sample to work [message #674657] Fri, 27 May 2011 18:32 Go to next message
Neil Goldsmith is currently offline Neil GoldsmithFriend
Member
Trying to follow along with the example code and get that running by following the code in the documentation, but even that is not coming up. It can't seem to load my DiagramTypeProvider:
!ENTRY org.eclipse.graphiti 4 0 2011-05-27 14:23:49.984
!MESSAGE org.eclipse.core.runtime.CoreException: Plug-in GraphitiMySample was unable to load class com.avaya.graphitieditor.MyGraphitiDiagramTypeProvider.
Code is extremly simple (just started the tutorial).
I have 2 classes and a plugin. It appears to not load my DiagramTypeProvider, but not sure why. Everything seems to be in place. I've included my .log file with more stack trace in this message. Thanks!
MyGraphitiDiagramTypeProvider.java
package com.avaya.graphitieditor;
import org.eclipse.graphiti.dt.AbstractDiagramTypeProvider;
public class MyGraphitiDiagramTypeProvider extends AbstractDiagramTypeProvider {
	public MyGraphitiDiagramTypeProvider() {
	    super();
	    setFeatureProvider(new MyFeatureProvider(this));
MyFeatureProvider.java
import org.eclipse.graphiti.dt.IDiagramTypeProvider;
import org.eclipse.graphiti.ui.features.DefaultFeatureProvider;
public class MyFeatureProvider extends DefaultFeatureProvider {
    public MyFeatureProvider(IDiagramTypeProvider dtp) {
        super(dtp);
plugin.xml:
<?eclipse version="3.4"?>
<plugin
   id="com.avaya.graphitieditor"
   name="MyGraphiti Plug-in"
   version="6.0.0.0701"
   provider-name="test"
   class="graphitimysample.GraphitiMySamplePlugin">
  <extension
      point="org.eclipse.graphiti.ui.diagramTypes">
    <diagramType
      description="This is the diagram type for my Graphiti tutorial"
      id="GraphitiMySample.MyTutorialDiagramType"
      name="Neil Graphiti Tutorial Diagram Type"
      type="myGraphititutorial">
    </diagramType>
  </extension>
  <extension
      point="org.eclipse.graphiti.ui.diagramTypeProviders">
    <diagramTypeProvider
      class="com.avaya.graphitieditor.MyGraphitiDiagramTypeProvider"
      description="This is my editor for the Graphiti tutorial"
      id="GraphitiMySample.MyTutorialDiagramTypeProvider"
      name="Neil tutorial editor">
      <diagramType
        id="GraphitiMySample.MyTutorialDiagramType">
      </diagramType>
    </diagramTypeProvider>
  </extension>
</plugin>
  • Attachment: .log
    (Size: 25.99KB, Downloaded 306 times)
[Updated on: Fri, 27 May 2011 18:36]
Report message to a moderator
Re: Trying to get the sample to work [message #674682 is a reply to message #674657] Fri, 27 May 2011 21:25 Go to previous messageGo to next message
Member
I got it working. The plugin had some issues I had to fix.
Re: Trying to get the sample to work [message #675349 is a reply to message #674657] Tue, 31 May 2011 08:46 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Neil,
the reason is that your DiagramTypeProvider is registered for a wrong
diagram type:
<diagramType
</diagramType>
You need to register it for "myGraphititutorial"
HTH,
Michael
"Neil Goldsmith" wrote in message news:iroq71$11r$1@news.eclipse.org...
super();
super(dtp);
plugin.xml:
<plugin
<extension
<diagramType
</diagramType>
</extension>
<extension
<diagramType
</diagramType>
</extension>
</plugin>
Re: Trying to get the sample to work [message #675436 is a reply to message #675349] Tue, 31 May 2011 14:20 Go to previous messageGo to next message
Member
Thanks Michael,
I found the bug on my end, but from what you are saying, don't you match up the ID from the diagramType ext point to your Diagram type ID attribute when you define your DT Provider? I followed the tutorial in the docs and structured my plugin nearly the same. Mine seems to be working fine now when I followed a similar structure to the code below from the tutorial.
<?eclipse version="3.0"?>
<plugin>
  <extension
    <diagramType
      id="org.eclipse.graphiti.examples.tutorial.diagram.MyTutorialDiagramType"
      name="My Graphiti Tutorial Diagram Type"
      type="mytutorial">
    </diagramType>
  </extension>
  <extension
      class="org.eclipse.graphiti.examples.tutorial.diagram.
      name="My tutorial editor">
      <diagramType
        id="org.eclipse.graphiti.examples.tutorial.diagram.MyTutorialDiagramType">
      </diagramType>
  </extension>
</plugin>
Re: Trying to get the sample to work [message #675735 is a reply to message #675436] Wed, 01 June 2011 10:17 Go to previous messageGo to next message
Neil,
yes, actually this is what I meant to say. Re-reading my answer again, I see
it is somewhat misleading.
Michael
"Neil Goldsmith" wrote in message news:is2sus$27o$1@news.eclipse.org...
Thanks Michael,
<plugin>
<extension
<diagramType
type="mytutorial">
</diagramType>
</extension>
<extension
<diagramType
</diagramType>
</extension>
</plugin>
Re: Trying to get the sample to work [message #1067367 is a reply to message #675436] Mon, 08 July 2013 12:44 Go to previous messageGo to next message
Heeren Sharma is currently offline Heeren SharmaFriend
Hey Neil,
I am facing the similar problem. I have successfully registered one DiagramType in one plugin project. But now when I created new Plugin project and try to register new DiagramType then I am not getting this new DiagramType in the list of graphiti example section.
Any kind of direction will be helpful.
Thanks.
Heeren
[Updated on: Mon, 08 July 2013 12:45]
Re: Trying to get the sample to work [message #1067374 is a reply to message #1067367] Mon, 08 July 2013 13:05 Go to previous messageGo to next message
Heeren,
have you checked the Eclipse error log for any execptions during startup?
Michael
Re: Trying to get the sample to work [message #1067477 is a reply to message #1067374] Tue, 09 July 2013 00:08 Go to previous message
Hi Michael,
Thanks for the hint. I got it working now. I suppose Error occurred as I have added
"org.eclipse.graphiti.mm.source" dependency. I changed manually the MANIFEST.MF file's entry to "org.eclipse.graphiti.mm".
Though I notice a really strange behavior. When I try to add "org.eclipse.graphiti.mm" dependency from the dependencies tab, then it doesn't show this dependency in other project, but only the "source" one. Can you verify or explain this behavior?
Heeren
Previous Topic:Problem with API changes in newest Graphiti Version
Next Topic:Insert a PictogramElement into another
Current Time: Fri Sep 24 19:40:53 GMT 2021
Powered by FUDForum. Page generated in 0.02333 seconds
