Re: [EEF] Label of Group widget is not generated [message #682034 is a reply to message #674644] |
Fri, 10 June 2011 09:05 |
Originally posted by:
Hi Nathalie,
We were in the rush for EEF Rc4 ( final ).
We've fixed this, so you can download the latest stable build to
re-generates your code.
Le 27/05/2011 19:18, Nathalie a écrit :
> Hello,
> I think I am running into a bug but I am not sure. I am using Eclipse
> 3.7.rc1(I20110512-2000) and EEF 0.9.0 release(v20110429-0823).
> I start with brand new EEF models that I got by clicking on Initialize
> EEF Editor on my .ecore file. Then I run the Generate EEF architecture
> on the .eefgen model associated to the .components model of my ecore
> (not the one associated to the editor, they are different).
> Once all the architecture is generated all the classes in the
> xxx.parts.forms and xxx.parts.impl packages display the same error. It
> looks like this:
> SmmMessages.AggregatedMeasurementPropertiesEditionPart_PropertiesGroupLabel
> cannot be resolved or is not a field
> SmmMessages is the class that contains all the externalized String
> generated. A look at this file shows that it is missing all the
> xxx_PropertiesGroupLabel String.
> Also I have this as a warning in the log file for each class:
> org.eclipse.acceleo.engine.AcceleoEvaluationException: Undefined guard
> group.representation.name.=('Group') at line 34 in Module
> ContextMessages for block for
> (viewsRepository.eAllContents(views::Container)) separator('
> ') ? (group.representation.name.=('Group')). Last recorded value of self
> was org.eclipse.emf.eef.views.impl.ViewImpl@732d5e15 (documentation:
> null) (name: Annotation) (explicit: true).
> at ContextMessages.ContextMessages(ViewsRepository)(ContextMessages.mtl:34)
> at ContextMessages.ContextMessages(ViewsRepository)(ContextMessages.mtl:20)
> at ContextMessages.ContextMessages(ViewsRepository)(ContextMessages.mtl:18)
> I didn't have this problem before I moved to the 0.9.0 release version,
> I check that the previous version of the SmmMessages class contains all
> the xxx_PropertiesGroupLabel messages.
> So am I missing something or this is really a bug?
> Thanks.
Stéphane Bouchet, OBEO
FUDForum. Page generated in 0.03062 seconds
