Re: Extend XML Editor [message #674020 is a reply to message #673976] |
Wed, 25 May 2011 14:20 |
On 25-May-11 05:15, MarcoGT wrote:
> Hi all,
> this is my first post here.
> I would like to add some features to XML default editor.
> I am new to plugin development and plugin extensions.
> How can I start?
> Thanks
> Bye
> Marco
To get your feet wet in plug-in development, may I suggest Lars Vogel's
site: http://www.vogella.de. He has a tutorial or two on RCP, etc.
Re: Extend XML Editor [message #674093 is a reply to message #674044] |
Wed, 25 May 2011 20:01 |
Sounds like you don't have the dependencies. The XML Editor isn't entirely provided by a single plug-in, you either have to have them all as part of the Target Platform or also checked out into your workspace. The simplest way to get them into your Target Platform is to have WTP installed.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Extend XML Editor [message #674095 is a reply to message #674093] |
Wed, 25 May 2011 20:02 |
_
Nitin Dahyabhai
Re: Extend XML Editor [message #674210 is a reply to message #674101] |
Thu, 26 May 2011 07:08 |
MarcoGT Messages: 77 Registered: May 2011 |
Member |
Ok, now I have errors in:
XMLValidatorPreferencePage.java (method clearCatalogCache() is undefined)
XMLCatalogEntriesView.java (INDICATE_NO_DOCUMENT_ELEMENT and USE_PROJECT_SETTINGS cannot be resolved)
Where can I find these sources?
Now in my workspace I have:
org.eclipse.wst.see.ui
org.eclipse.wst.xml.ui
But still I have errors listed above.
Which others plugins do I need?
EDIT: I solved checking-out org.eclipse.wst.xml.core, but this is strange because:
XMLCorePreferenceNames.INDICATE_NO_GRAMMAR was fine, but XMLCorePreferenceNames.INDICATE_NO_DOCUMENT_ELEMENT wasn't, why?
And, org.eclipse.wst.xml.core.jar was already in my plugins folder.
BTW, now I have no errors.
Marco
[Updated on: Thu, 26 May 2011 09:35] Report message to a moderator
Re: Extend XML Editor [message #675637 is a reply to message #674270] |
Wed, 01 June 2011 04:26 |
On 5/26/2011 7:16 AM, MarcoGT wrote:
> Ok, I followed the tutorial and it works fine but on the console I got
> some warnings, for example:
> ENTRY org.eclipse.osgi 2 0 2011-05-26 13:06:37.321
> !MESSAGE One or more bundles are not resolved because the following root
> constraints are not resolved:
> !SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-26 13:06:37.321
> !MESSAGE Bundle
> reference:file:/Z:/eclipse_new/eclipse/plugins/org.eclipse.wst.xsd.ui_1.2.304.v201101251958.jar
> was not resolved.
> !SUBENTRY 2 org.eclipse.wst.xsd.ui 2 0 2011-05-26 13:06:37.321
> !MESSAGE Missing required bundle org.eclipse.wst.sse.ui_[1.2.0,1.3.0).
> And a some more.
> At the moment I have checked-out from CVS the following plugins:
> 1) org.eclipse.wst.sse.ui
> 2) org.eclipse.wst.xml.core
> 3) org.eclipse.wst.xml.ui
> Do warning mean I need also some other plugins?
It looks like you may have checked out the versions from HEAD, but not
using an Indigo build. "Missing required bundle
org.eclipse.wst.sse.ui_[1.2.0,1.3.0)" points to this being just that
kind of version mismatch.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
_
Nitin Dahyabhai
Re: Extend XML Editor [message #676682 is a reply to message #675987] |
Mon, 06 June 2011 06:33 |
Member |
Ok, at the moment I am using Indigo release and I do not have those warnings anymore.
I explain better my goal.
I have an XML file which represents a series of step to be taken.
What can be done inside each step is defined in a second XML file.
So, the content assist is for the values of attributes and not for the attributes themselves, or for tags as the "classic content assist"
Is it possible to query this XML file using XPath and using as argument of my XPath function what has be written by user?
I tried to query an XML file using XPath and it works. But, now, I would like to query according to what user wrote.
I make an example:
<employee level=" At this point the content assist should display the available level. So, I have to write an XPath expression to query an external XML file and ask for the all available levels, then, present them in the a "content-assist-like"
No problem about XPath, I know it; my problem is to get the attribute and then represent the values...
How do I get the last inserted attribute?
Marco
[Updated on: Mon, 06 June 2011 11:50] Report message to a moderator
Re: Extend XML Editor [message #676966 is a reply to message #676682] |
Tue, 07 June 2011 06:28 |
Member |
Ok, some news.
I saw that plugin org.eclipse.wst.sse.ui provides the extension point completionProposal.
Attached to this there are also some examples.
These example propose what I need, that is, suggestion for attribute values.
I think values comes from DTD file.
But, I have to improve this taking values from an XML file.
The attributes values are the tags in my external XML file.
[Updated on: Tue, 07 June 2011 08:15] Report message to a moderator
FUDForum. Page generated in 0.04486 seconds
