[ATL] Catch and modify existing object in target model [message #673426] |
Mon, 23 May 2011 15:40 |
Patrick Schmitt Messages: 87 Registered: July 2009 |
Member |
Hello guys,
I have a small ATL algorythm which is creating "Distributor" objects in a target model. The algorythm checks if no "Distributor" object with the same name already exists, just in that case a new "Distributor" object is created.
For the case the "Ditributor" object already exists I have to add children to it(if the object not exists this add is normally done in the lazy rule during its creation).
Here is my small commented algorythm, i hope u understand it and can give me a hint.
rule RootElement {
from
s : A!Product
to
t : B!BCModel (
-- add a category and pass all references to its rule
categories <- thisModule.addArmature(s.references.asOrderedSet())
lazy rule addArmature{
from
s : OrderedSet(A!PartReference)
to
t : B!Category(
name <- 'Armature',
-- here we add distributors with a helper
-- to avoid adding distributors with same name twice
distributors <- thisModule.fetchDistributors(s)
lazy rule addDistri{
from
s : A!PartReference
to
t : B!Distributor(
name <- s.part.distributor,
blocks <- thisModule.addBlock(s)
lazy rule addBlock{
from
s : A!PartReference
to
t : B!PartBlock(
name <- s.part.name,
price <- s.part.cost * s.amount -- calc proper price
helper def : fetchDistributors(refs : OrderedSet(A!PartReference)) : OrderedSet(B!Distributor) =
refs->iterate(e ; retValue : OrderedSet(B!Distributor) = OrderedSet{} |
if e.part = OclUndefined
then retValue
else
if e.part.distributorExists(retValue).oclIsTypeOf(B!Distributor) = false
then retValue.append(thisModule.addDistri(e))
else
-- how to catch the existing distributor
-- and add a Partblock(how its done in addBlock rule)
-- with information of the iterator ???
retValue
endif
endif
-- this helper return OclUndefined if distributor does not exist, else the distributor instance
helper context A!Part def: distributorExists(distris : OrderedSet(B!Distributor)) : B!Distributor =
distris->iterate(e; retValue : B!Distributor = OclUndefined |
if e.name = self.distributor
then e
else
retValue
endif);
[Updated on: Mon, 23 May 2011 15:54] Report message to a moderator
FUDForum. Page generated in 0.02514 seconds
